This has persisted in cropping up and complicating troubleshooting of various other problems so I thought it’s worth more visibiliy:
Fedora 39, at least when fresh installed, somehow is set up so that when the kernel is updated, the option to make the just-installed kernel version the default on boot is not enabled. This is the opposite of default Fedora behavior from as far back as I can remember (decade or so).
It’s been covered in various “adjacent” threads here. The summary to fix this is that:
If it doesn’t exist, create (as root) the file /etc/sysconfig/kernel.
In that file, these two options should be set as:
# UPDATEDEFAULT specifies if new-kernel-pkg should make
# new kernels the default
UPDATEDEFAULT=yes
# DEFAULTKERNEL specifies the default kernel package type
DEFAULTKERNEL=kernel-core
If you’ve already installed the kernel version you want made default, either of these steps should complete the fix (using 6.6.10 currently in the testing “channel”):
sudo dnf reinstall kernel-core-6.6.10 in a terminal.
or
Reboot.
When the Framework logo appears, press Esc every few seconds. The grub menu should appear.
If you pressed Esc one time too many, you’re in the grub shell, just ctrl-alt-del to try again (instructions for a better way welcome).
Select the (latest) kernel you want to boot into.
Once you’ve rebooted the “kernel update makes new version the default” should be the behavior going forward.
(Aside, and separate discussion really: I want to reproduce this in a VM and open a bug on the Redhat Bugzilla but somehow I can’t create a new VM.)
I am experiencing no issues with this, and the only time I have in the past is when I have explicitly changed it and forgotten about it. This looks less like a bug and more like a result of running on the testing “channel”.
I also cannot replicate it using the default install media in either a VM or on bare metal. If it cannot be replicated there is not much that can be done.
that was just the latest kernel, installed while it was still in updates-testing, before it got promoted to stable (which wouldn’t have made a difference as far as this issue goes). The behavior had been consistent for me (and several others in the forum) at least a while ago.
It could well be then that this was fixed, does the install ISO (specifically, live Workstation) itself get periodically updated? FWIW I did this fresh install just days after F39 went GA in November.
Anyway, if it’s no longer reproducible that’s good, it is/was interfering with other troubleshooting.
Yeah, I have no idea why this isn’t consistent. I was theorizing earlier (see above) that the installer within the ISO itself (anaconda?) had been updated in a subsequent version of the ISO.
However from what I can see opening https://download.fedoraproject.org/pub/fedora/linux/releases/39/Workstation/x86_64/iso/, any mirror I get only has the November 1st image.
I went with defaults during installation, only “option” was selecting LUKS.
What else… grubby invocations during the early days to add the amdgpu and ACPI alarm kernel args - somehow those messed up the default? Shouldn’t happen…
