The solution has been mentionned already.
Font scaling is not the same as full scaling, and leads to completely satisfying results.
No fuzziness.
No fuzziness.
While the fuzz is gone I saw issues with the text not fitting into the UI pane/having to resize the window elements to fit the greater text size.
@Usernames Well, yeah… Let’s say “more satisfying results”.
Although, personally I haven’t had to resize UI elements so far.
It happens for some applications, but far from all of them.
As far as my personal use goes, the font scaling has been a really satisfying solution.
I think some of this does depend on distro. On Fedora I have no blurry text, but on Ubuntu it is horrendous. I have not had time to dig into why. I.e. whether it has to do with aliasing, choice of font, base font size, etc
Absolutely but it is a downside of the “font size” approach.
I’ve settled on 150% with 1x fonts and that works for me, good we have options! ![]()
:: Feedback from the internet on Framework’s Linux-incompatible HiDPI display ::
Fractional Scaling…. still an issue in 2023
After fixing firefox, I noticed Slack was incredibly fuzzy…. The only option seem to be spending hours trying to find how to enable every random app, or disable fractional scaling and have a hard time reading stuff because it’s a bit small.
— 2023-10-12, A Developer’s Experience: Framework 13 AMD 7040 Series
Appreciate the feedback. However to be clear, incompatible would suggest that it does not work - it does, be it fractional scaling on Linux can be an acquired taste. I use it every single day. ![]()
This reviewer had very specific expectations on how fractional scaling and how applications built for X, work with Wayland in general.
Again, fair feedback and we hear them. But I need to be clear on that point - electron apps specifically, their Wayland compatibility would fall in line with their individual developers.
