Nope, it’s all the same, glad you have a working laptop! I love computers.
Recommend you pin that image for a bit and see how it handles over the next few major kernel upgrades as they come down from Fedora.
Running into somewhat similar behavior on my AMD 13 with both the Mediatek card and Intel 210. General behavior seen is as soon as download bandwidth usage increases (upload seems unaffected), latency goes through the roof, speed tanks.
Steps to reproduce:
Symptoms: Download speed will pick up as normal then completely stall out, ping latency will spike to several seconds while this speed crash occurs.
Tested on:
Network is configured so band steering is disabled, network is 5ghz only, single AP (Unifi A6 Pro).
So with my Eero 6E setup, two mesh router updates later and it has not been a problem since at my home office. Bazzite/Bluefin, Fedora and Ubuntu. I’d need to see output from this being run to know for sure if this is the same thing, as it would catch a frequency change (even if you believe it’s disabled, I’ve seen routers not actually do it).
In my case, at the time, it was poor handing off of 5 to 6 ghz.
Also worth grabbing journalctl --since "2024-05-16 13:50:00" --until "2024-05-16 13:58:00"
(adjusting the times to match your occurrence) to see if anything new jumps out. Often times nothing does, but sometimes it can. VPNs that folks forgot about that are installed, etc.
Do you need the log files or just the console output?
If it’s just the console output here you go:
iw is already installed.
lshw is already installed.
[sudo] password for USERNAME:
Interface: wlp1s0
Monitoring WiFi on interface wlp1s0 for 3600 seconds. Logs are being saved to /home/USERNAME/iw_logfile.log and /home/USERNAME/ping_logfile.log.
Processes started: iw PID = 5490, ping PID = 5491
Monitoring completed.
Analyzing the log files for drops or freezes...
Analysis completed. Check the log files for details.
Any updates here?
I’ve got this issue with a brand new framework 13 on bazzite. Looking forward to hearing more about how to fix… I have the AMD wifi module,
One of the support reps told me to try the :testing tag on bazzite and at least today so far my wifi hasn’t dropped.
uname -r
6.15.4-103.bazzite.fc42.x86_64
Switching to iwd actually really seems to have helped me get better performance and connection strength to my AP as well
