Troubleshooting system freeze: Arch Linux
Hello, I’m looking for help troubleshooting system freezes on my Framework 16.
Host: Framework Laptop 16
Kernel: Linux 7.2.6-arch2-1
Window manager: Hyprland 0.56.2 (Wayland)
CPU: AMD Ryzen 7 7840HS
iGPU: AMD Radeon 780M
dGPU: AMD Radeon RX 7700S
Memory: 16G
The system freezes started occurring sometime around September 18th. Here are the observable symptoms:
I am usually doing some fairly lightweight work. Hyprland is open, and I typically have firefox, an editor, and some terminal (kitty) windows open. RAM usage sits on average between 3-6G.
Before the freeze occurs, I usually notice the fans spin faster (although CPU and GPU temps are still well within normal operating temperature), and RAM usage might increase slightly (by about 1G or so). Sometimes, I see clamav or snapper running, which may or may not be accounting for the increased fan speed and RAM usage.
Then the system freezes for anywhere between 3 seconds and 60 seconds. I have been unable to pinpoint what is causing the freeze, and thus have not been able to create a set of steps to duplicate the freeze on my machine. While the system is frozen, I can spawn new terminal windows, but they do not load and I cannot type in them. All windows/applications (current or newly created windows) are unresponsive. However, I can still move the mouse and switch workspaces in Hyprland. Using any of the SysRq key combos do not register until after the freeze ends.
And I want to note that the system freeze ALWAYS goes away without user intervention after somewhere between 3 and 60 seconds. Once the system is responsive again, any SysRq key combos pushed during that time print to journalctl -f. I often notice that journalctl logs that snapperd service has been deactivated successfully once the system freeze ends and resumes normal operation, but I do not know if this is related at all.
Any advice on how to collect more useful data/troubleshoot would be greatly appreciated.
There’s dmesg, which can help if there’s something happening at the kernel level, and Hyprland logs in $XDG_RUNTIME_DIR/hypr/$HYPRLAND_INSTANCE_SIGNATURE/hyprland.log.
You can also make ps or top script that logs the top CPU-using processes every 10 seconds or so.
You can try to force clamav to just one or two CPU cores and see if goes away.
Thanks for the suggestions. I’ve set up a ps script to keep logs, and I’ll try checking the Hyprland logs as well. Unfortunately dmesg doesn’t contain any messages around the times that the freezes occur.
SOLVED: The freezes were being caused by having BTRFS quotas enabled. Disabling BTRFS quotas fixed the problem. See more info here: [SOLVED] Troubleshooting system freeze: Framework 16, BTRFS, Quotas / Laptop Issues / Arch Linux Forums
