Which OS (Operating System)? Windows 11 24h2
Which Framework product : Laptop 12
Hi there,
I’m trying to install 5 laptop for my coworkers.
I’ve set up everything on one, and was planning to just copy it, and deploy it on the others with Acronis Snap Deploy (I’ll refer to it by Snap now).
But after a copy in the .tib type, when I get to deploy it I have an issue I’ve never seen before in 5 years of using it.
My research on the error E00770021 that I’m getting shows that either it’s a space problem or a path problem. As it’s literally the same PC out from the box, it can’t be a space problem, as for the path, I’ve never had this problem with any device before.
Trying multiple things, like changing the disk I was putting it on, redoing it on another USB port, removing all checks in the security boot, I now don’t know what to do next.
If there is something preventing cloning and deploys on frameworks PC I’d be thrill to know about it, so that I can disable that bad boy.
Thanks for reading, I hope you have everything here to help me.
Sincerely,
Loup Ciosek
