Ubuntu 24.04 LTS won't finish installing
Which Linux distro are you using? Ubuntu 22.04 LTS
Which release version? 22.04.1
Which kernel are you using?
Which BIOS version are you using? 3.05
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series
The installation process halts, the window closes after I enter my name, computer name, and password. I ran the updates in the terminal as suggested but upon reboot the computer advised that there was no boot media available.
I know I’m missing some step here but haven’t found it yet. I’ve installed Ubuntu about 25 times over the years but this situation is a new one for me.
The computer runs fine with the live boot USB connected. Everything seems to work correctly.
Suggestions?
