Updated bazzite, upon reboot laptop won't recognize SSD as boot drive
Bazzite
Which release version?
Current
Which kernel are you using?
Unsure
Current
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Ryzen
I’m having an issue where I update bazzite and when I rebooted, framework doesn’t recognize the boot drive as existing at all. It sees the SSD right there and the live bazzite USB recognizes bazzite as installed already but the repair tool says EFI directory missing. I tried creating a new EFI directory in FAT 32 as the only things coming up on lsblk are the nvme0n1p2 ext4 and nvme 0n1p3 btrfs file. Is there a way to get the EFI to be recognized by the BIOS, or repair bazzite with the EFI missing and it’s unable to repair when I click on the SSD
