Hi All,
Just saw some info about the USB4 ports on the 13 (AMD AI), mentioning the back 2 are enabled for this. However I can only get the back right one working correctly, that is with DP+Power+USB devices.
The other dont seem to be working for that, or at lest with the full bandwidth. I’ve seen windows might have better drivers for this and make it work however I’d like to stay on Fedora if possible…. Not a massive deal-breaker just a preference…
Would anyone know for sure that its the laptop or the OS? Thanks.
Which Linux distro are you using? Fedora GMONE
Which release version? Latest (42)
Which kernel are you using? Default
Which BIOS version are you using? Latest (3.0.4)
Which Framework Laptop 13 model are you using? AMD Ryzen™ AI 300 Series
