USB-A Extension stops working after shutdown until i unplug and plug back in
Hi to all i have got my framework last week. But im having this issue and its making me crazy. I use my laptop as usual then i power off. When i power back on the port completely stops working. my mouse is dead and i need to pull up my laptop and re-plug the expansion and since im connected to a monitor and using it mostly in clamshell mode it is annoying me.
How can i debug this issue, should i create a ticker ? it also happend when i chaanged its port from right-down to right-upper port.
edit: i searched through forums and many users have the same issue. on this thread users still reportingh the same issue but its marked as solved. These kind of issues should not appear on a device that is brand new and i think enough time have passed for framework team to solve these kind of issues. i bought this laptop because it fits my need and gives me peace of mind knowing i can repair everything but im starting to regret that choice with these little issues popping up (i got a fitting problem with my rams on slot 1,solved it by removing sticker but its annoying because its sodimm ram so framework should support it out of the box).
Fedora 43 default installation secure boot on nothing is changed on my system. Ryzen ai 5 340
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
        Vendor: INSYDE Corp.
        Version: 03.05
Linux fedora 6.17.12-300.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Sat Dec 13 05:06:24 UTC 2025 x86_64 GNU/Linux
LSPCI INFO
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Krackan IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1124
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1125
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1125
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1124
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1126
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1126
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1124
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 1124
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Krackan Internal PCIe GPP Bridge 0 to Bus A
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Krackan Internal PCIe GPP Bridge 0 to Bus B
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Krackan Internal PCIe GPP Bridge 0 to Bus C
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Krackan Data Fabric; Function 7
bf:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal]
c0:00.0 Network controller: MEDIATEK Corp. MT7925 (RZ717) Wi-Fi 7 160MHz
c1:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Krackan [Radeon 840M / 860M Graphics] (rev c3)
c1:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller
c1:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Strix/Krackan/Strix Halo CCP/ASP
c1:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1128
c1:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Audio Coprocessor (rev 71)
c1:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Ryzen HD Audio Controller
c2:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Krackan PCIe Dummy Function
c2:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] Strix/Krackan/Strix Halo Neural Processing Unit (rev 20)
c3:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1118
c3:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 111c
c3:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 111e
c3:00.5 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1120
c3:00.6 USB controller: Advanced Micro Devices, Inc. [AMD] Device 1121
LSUSB INFO
Bus 001 Device 002: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix Fingerprint USB Device
Bus 003 Device 002: ID 32ac:0003 Framework DisplayPort Expansion Card
Bus 003 Device 003: ID 32ac:001c Framework Laptop Webcam Module (2nd Gen)
Bus 003 Device 004: ID 0e8d:0717 MediaTek Inc. Wireless_Device
Bus 003 Device 005: ID 046d:c543 Logitech, Inc. USB Receiver
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Here is the dmesg output
https://rentry.co/e5o4szty
