System Information
- Framework Laptop 13
- AMD AI 300 Series (AI 5 340)
- Windows 11
- 32 GB DDR5-5600 RAM
- 2 TB SSD
Hi everyone,
I purchased a Framework Laptop 13 with the AMD AI 5 340 motherboard about 2 months ago, and I’ve recently started experiencing an issue with one of the USB-C ports.
The affected port is the 4th USB-C port (the second port on the right side). I normally have a USB-A Expansion Card installed there with my wireless mouse dongle connected to it.
Occasionally, the mouse suddenly stops responding, as if the port has stopped working. Initially, I thought the USB-A Expansion Card itself was faulty, so I replaced it with another USB-A Expansion Card, but the problem still occurs.
To rule out the mouse, I also tested with a different wireless mouse from ASUS, and the behavior was exactly the same. My primary mouse is a Logitech M171, which I used for almost a year on my previous computer without any issues.
When the problem occurs, the only way to restore functionality is to remove the Expansion Card and plug it back in. After that, everything works normally again until the issue randomly reappears.
I’ve already tried:
- Updating Windows 11
- Installing the latest AMD drivers
- Reverting to older Framework driver packages
- Updating back to the latest Framework drivers
Unfortunately, none of these steps have made any difference.
At this point, I’m not sure whether this is:
- A problem with that specific USB-C port
- A Windows power management issue
- A driver or firmware issue
- Or a hardware fault with the motherboard
Has anyone else with an AMD AI 300 Series Framework 13 experienced something similar? If so, were you able to identify the cause or find a solution?
Any troubleshooting suggestions would be greatly appreciated.
Thanks!
