USB port charging dead?
If i try to charge the laptop through one of the left bottom port, the laptop doesn’t charge. It works with all other ports.
However, it does work with detecting USB keys. It is not a dead USB expansion card, it doesn’t charge either if i connect directly the cable to the port of the mainboard. Is it possible that only the charging lane is dead on the mainboard and not the data lane? Is it possibly a software/firmware issue?
I’m on a Framework 13, 12th Gen Intel i7-1260p running Fedora 41.
