For anyone who knows their Framework Laptop 13 mainboards backward and forward, I’ve got an increasingly bizarre and baffling problem that’s been going on for the past year and a half - if you’ve got solutions, I’d love to hear them!
Long story short, all four USB-C ports on my 11th Gen Intel Core i7-1165G7 mainboard appear to send and receive power, but no data whatsoever - except when my HDMI or SD Card expansion cards are attached.
All of my expansion cards (4x USB-A, 2x USB-C, HDMI, SD Card) have been used with another mainboard and work just fine; it seems to be a problem with this mainboard in particular.
This isn’t a life-or-death situation, since I’ve been able to purchase another 11th Gen Intel Core mainboard as of earlier this year, but I am intensely curious about what could possibly be causing this problem - plus, if I can get my original mainboard working properly, I’ll at least have a second mainboard that I can use for some cool cyberdeck project or something.
I’ve been running Zorin OS 16 and more recently Zorin OS 18.1; the exact same behaviour has been observed under Windows 11.
Here’s the long story:
I bought this particular Framework Laptop, along with the USB-A, USB-C, and HDMI expansion cards, in early 2022 and have been using it ever since. (Note: I’ve ruled out the issue with the shielding around the USB ports on late-2021 Framework laptops.)
One day in summer 2025, I tried to plug in a USB printer, and the printer simply wasn’t recognized. I did everything I could - restarting CUPS, reinstalling proprietary drivers - to make the printer operational, but no luck. Soon enough, I realized that no USB peripherals were being recognized at all - although the power supply somehow still delivered power, and USB devices (such as my phone) would still charge from the Framework. I’m not sure what could have precipitated this, except for possibly:
- the extended use of a third-party 100W USB-C PD cable when my Framework USB-C power supply cable wore out (alarmingly fast, I might add);
- I had been traveling for several weeks and often left the Framework in sleep mode for longer-than-usual periods of time
- connecting my phone (an old Google Pixel 2) to the Framework for USB file transfers (something the phone is apparently no longer capable of either, but that’s another story).
After multiple mainboard resets, I contacted Framework Support. They told me that the mainboard shows signs of water damage (which I now reject as a possible cause due to the HDMI and SD Card expansion cards functioning normally; see below), and recommended replacing the mainboard entirely.
Along the way, I posted here, and got a few ideas for workarounds or, potentially, how the mainboard might be able to be fixed. I corresponded with a local technician, who pointed out that my last line of defense might be to update the UEFI/BIOS firmware, which would have to be done under Windows (as one of the key firmware updates wasn’t available for download on Linux). I bought a small backup SSD, installed Windows 11 on it, and observed the same behaviour before and after the BIOS update.
After much back-and-forth with Framework Support, I gave up hope that the USB ports would ever work properly again. I purchased another 11th Gen Intel Core mainboard with a slightly lower spec (the i5-1135G7); I also bought a new USB-C power supply and cable, along with the newly-released SD Card expansion card.
(Honestly, Framework Support was eminently unhelpful in all of this; by this time, components in the power supply as well as the keyboard / Input Cover had begun to wear out, the latter having apparently succumbed to a known issue. Despite this, the most they would offer me was a replacement USB-C cable, which was frankly a pretty paltry courtesy. With no other alternative in sight, I gritted my teeth and purchased replacement parts at my own expense. I was not impressed.)
With my replacement parts in hand, I switched all the hardware (SSD, RAM, etc) over to the new mainboard and installed it with no issues. Everything, including the USB ports, functioned quite happily after that (even though I was now over $500 CAD poorer - a prohibitive expense for somebody who generally struggles to make ends meet, and likely enough to have bought a whole new non-Framework laptop).
The old mainboard sat in a box in my closet for several months. Occasionally, I’ve been inspired to get it out, swap it with the new mainboard, and see if I can think of anything that hasn’t yet been done to fix this issue - at one point, I happened to plug in my SD Card expansion card, inserted an SD card, and the SD card mounted as though nothing was wrong.
Most recently, this afternoon I installed the old mainboard again to try a few new things. Neither of my hopeful fixes worked, as usual, so I’m posting here once again.
Here’s what I’ve been observing, with output from dmesg:
When I insert a USB-A expansion card and plug in an ordinary USB-A flash drive, nothing happens, and dmesg returns absolutely nothing.
When I insert a USB-A expansion card, plug in a powered USB-A hub, and plug an ordinary USB-A flash drive into the hub, nothing happens.
When I attempt to plug an ordinary USB-A flash drive into the underlying USB-C port (via a USB-C to USB-A cable and a female-to-female USB-A adapter), nothing happens either.
I’ve also previously tried to connect my phone (old Google Pixel 2) to this mainboard, using a USB-C to USB-C cable, both via the USB-A and USB-C expansion cards and directly to the underlying USB-C port, also with no results.
When I insert a USB-C expansion card and plug in my standard Framework USB-C power supply, the computer begins to draw power from the power supply as expected, but dmesg returns the following (mostly errors):
[ 2890.900176] usb 3-6: new full-speed USB device number 5 using xhci_hcd
[ 2891.074430] usb 3-6: device descriptor read/64, error -71
[ 2891.356298] usb 3-6: device descriptor read/64, error -71
[ 2891.635201] usb 3-6: new full-speed USB device number 6 using xhci_hcd
[ 2892.017256] usb 3-6: device descriptor read/64, error -71
[ 2892.497362] usb 3-6: device descriptor read/64, error -71
[ 2892.598516] usb usb3-port6: attempt power cycle
[ 2893.041237] usb 3-6: new full-speed USB device number 7 using xhci_hcd
[ 2893.041494] usb 3-6: Device not responding to setup address.
[ 2893.246466] usb 3-6: Device not responding to setup address.
[ 2893.454155] usb 3-6: device not accepting address 7, error -71
[ 2893.454375] usb 3-6: WARN: invalid context state for evaluate context command.
[ 2893.833233] usb 3-6: new full-speed USB device number 8 using xhci_hcd
[ 2893.833460] usb 3-6: Device not responding to setup address.
[ 2894.038495] usb 3-6: Device not responding to setup address.
[ 2894.246251] usb 3-6: device not accepting address 8, error -71
[ 2894.246431] usb 3-6: WARN: invalid context state for evaluate context command.
[ 2894.246600] usb usb3-port6: unable to enumerate USB device
- However, when I insert my SD expansion card and subsequently insert an SD card into the slot, the SD card is immediately recognized and mounted, and dmesg returns the following (all very promising except for the last line, which doesn’t seem to matter as the SD card appears to be operating normally):
[ 2289.440584] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 2289.454193] usb 2-2: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
[ 2289.454207] usb 2-2: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 2289.454211] usb 2-2: Product: SD Expansion Card
[ 2289.454216] usb 2-2: Manufacturer: Framework
[ 2289.454219] usb 2-2: SerialNumber: 000000000002
[ 2289.513444] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 2289.513836] scsi host0: usb-storage 2-2:1.0
[ 2289.514082] usbcore: registered new interface driver usb-storage
[ 2289.518628] usbcore: registered new interface driver uas
[ 2290.579832] scsi 0:0:0:0: Direct-Access Generic MassStorageClass 0002 PQ: 0 ANSI: 6
[ 2290.580494] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2291.154743] sd 0:0:0:0: [sda] 31268864 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 2291.155790] sd 0:0:0:0: [sda] Write Protect is off
[ 2291.155800] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 2291.156652] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2291.176190] sda: sda1
[ 2291.176437] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 2291.585684] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
- And when I insert my HDMI expansion card and connect an HDMI projector, I get the usual second desktop screen through the HDMI projector, and dmesg returns the following:
[ 3516.141907] Registered IR keymap rc-cec
[ 3516.142141] rc rc0: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0
[ 3516.142274] input: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0/input18
My question is: what could possibly be wrong with this one particular mainboard, such that:
- the newer SD Card expansion card is recognized with little to no difficulty;
- the original HDMI expansion card is recognized with no difficulties whatsoever;
- neither my USB-A nor my USB-C expansion cards, with flash drives or other peripherals plugged in, seem to be recognized at all;
- nothing else that’s plugged into the underlying USB-C ports seems to be recognized either;
- the Framework USB-C power supply delivers power as expected, but returns errors in dmesg;
- my other mainboard seems to recognize all of the above expansion cards and other USB devices without issue?
What I have tried so far:
- more attempts at resetting the mainboard than I can count;
- updating BIOS firmware to v. 3.24 under Windows 11 (this update was not available for Linux via the command-line utility, and I had no way to get it onto a USB flash drive);
- opening the BIOS at startup and reloading optimal defaults;
- running this third-party script to rebind all USB devices;
- attempting to update BIOS firmware from the command line (did not update BIOS to v. 3.25);
- attempting to update BIOS firmware to v. 3.25 (using the SD Card expansion card in lieu of a USB flash drive); this did not work as the SD card was not recognized as bootable at startup, and it’s getting late enough in the day that I don’t feel like swapping out the SSD and running Windows 11
I would be so incredibly excited to hear any possible further suggestions. Now that the HDMI and SD Card expansion cards appear to be working without issue, I’m convinced that there has to be some way to get this mainboard to recognize plain old USB devices again - and honestly, I’d love to start using this mainboard again as it seems to run slightly faster. Thoughts?
(Edited to clarify that my HDMI expansion card was in fact original to this Framework Laptop, while the SD Card expansion card is newer; also elaborated on my eminently unhelpful experience with Framework Support. Finally, changed category to Community Support.)
