So, I’ve always had some kind of minor issues with USB on my FW16, but it seems like it is getting worse now.
- Headphone jack audio doesn’t always come up on boot
- Headphone jack audio sometimes randomly stops sometimes, and I have to reboot for it to work again
- System doesn’t charge if the charger is plugged into a forward port instead of the middle one
- Display doesn’t always come up if the HDMI expansion is in a front port (and started working when I moved it to the back on the other side).
I also get messages like this:
Jul 13 12:18:47 kitchen kernel: usb 7-1: device descriptor read/64, error -110
Jul 13 12:18:47 kitchen kernel: usb 7-1: new high-speed USB device number 3 using xhci_hcd
Jul 13 12:18:53 kitchen kernel: usb 7-1: device descriptor read/64, error -110
Jul 13 12:19:09 kitchen kernel: usb 7-1: device descriptor read/64, error -110
Jul 13 12:19:09 kitchen kernel: usb usb7-port1: attempt power cycle
Jul 13 12:19:09 kitchen kernel: usb 7-1: new high-speed USB device number 4 using xhci_hcd
Jul 13 12:19:14 kitchen kernel: xhci_hcd 0000:c3:00.4: Timeout while waiting for setup device command
Jul 13 12:19:20 kitchen kernel: xhci_hcd 0000:c3:00.4: Timeout while waiting for setup device command
Jul 13 12:19:20 kitchen kernel: usb 7-1: device not accepting address 4, error -62
Jul 13 12:19:20 kitchen kernel: usb 7-1: new high-speed USB device number 5 using xhci_hcd
Jul 13 12:19:25 kitchen kernel: xhci_hcd 0000:c3:00.4: Timeout while waiting for setup device command
Jul 13 12:19:31 kitchen kernel: xhci_hcd 0000:c3:00.4: Timeout while waiting for setup device command
Jul 13 12:19:31 kitchen kernel: usb 7-1: device not accepting address 5, error -62
Jul 13 12:19:31 kitchen kernel: usb usb7-port1: unable to enumerate USB device
Anyone know what’s going on? Is this a software issue, or is my hardware breaking over time? It does seem like it’s getting worse over time, it used to be occasional and I didn’t really care that much but it seems like now it is an issue in some way almost daily.
Which Linux distro are you using? NixOS
Which release version? 26.11.20260702.6517942 (Zokor)
Which kernel are you using? 7.1.2
Which BIOS version are you using? 03.07
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series / FRANMZCP07
(Edit: Specified headphone jack audio. The system’s speakers work, just not the USB headphone jack.)
