I have a Macbook Pro from 2017 and it contains 4 USB-C ports. One of these I use with a GaN charger which I have purchased separately, so that I can use the standard Mac charger and also have the additional GaN charger. It would be nice to use a USB-C port and include a Gan type of charger instead of the default charger that is included. Here is a random article: https://www.howtogeek.com/509209/what-is-a-gan-charger-and-why-will-you-want-one/
Using the USB-C port and a GaN charger seems like a more universal approach to charging a laptop.
Ps
A side note. I hope the new 16" will fit in a standard 15.4 laptop sleeve. As well as fit in a standard backpack that usually fits the 15.4 Macbook Pro laptops.
If they don’t go all the way to 48V with PD3.1 I could definitely see a barrel jack on a GPU expansion bay module, and then when you’re running on just iGPU then USB-PD will be enough.
Yah with the GPU module like Linus holding, if they dont go PD3.1, I have doubt in whether current PD protocol could handle it or not.
And the outer dimension is also something noticeable, as I had times that have to buy new backpack just to keep my new 16’ laptop on the go, as the old backpack can fit 16’ but slim ones XD.
For anyone who happens to stumble upon this thread, F16 is now confirmed to come with 180W USB-C PD charger and support up to 240W charging, maxing out the relevant USB-PD standard.
