Using other USB-C power supples
Is it safe to charge my Framework laptop using non-Framework USB-C power supplies? In particular, one that came with a Nintendo Switch (15V 2.6A)?
Use a USB-C power supply that is advertised as “generic” by the seller.
I remember having read stories of some gaming console charger that fried tablets or laptops plugged into it (see edit), I don’t remember if it was Nintendo or Sony, but anyway, in this unfortunate case the charger was clearly advertised as “for that specific gaming console”.
Edit: Sorry, after looking up, that was the other way around:
https://www.reddit.com/r/NintendoSwitch/comments/a1y53w/why_nonnintendo_usbc_cables_can_harm_your_switch/
But that also says that Nintendo weren’t following the USB-C specifications in their cable, which I thus wouldn’t trust to plug into my Framework (and I don’t know about their charger itself).
Personally I’m using Anker chargers for my Framework laptop, and they’re just perfect.
An other point is that you should use a charger that supports Power Delivery (PD).
I use a Nintendo Switch charger often with my FW - which is not an endorsement that anybody should - but it hasn’t caused any problems for me. It doesn’t charge as quickly as the Framework charger though, being a lower wattage.
