Alternatively give us a really good discount on a 12th/13th Gen board? I mean a really good one.
Iām serious.
Iām serious.
Unfortunately that is not an available option.
But maybe the ethical option?
Does that mean, after this mod, the RTC battery only charges from the main and not from the āmainsā supply.
It is not possible and simpler to use a DC to DC converter to output 3.3V to the RTC with a diode to stop reverse current ?
Even if I had an 11th gen board still, Iād pass on this mod. I have little experience with soldering and what little I have seems insufficient to perform this. This is where repair shops in customer areas can prove their worth. Seems to me that mod, while difficult shouldnāt take more than an hour or two. Shouldnāt be too costly to get it fixed then.
This is where I fall - Iām interested in the modification, but itās something that I will farm out, as itās likely beyond my ability to pull off. I have two machines that I may have it done on, depending upon cost.
This. If anyone in the western half of Oregon is willing to do this mod, Iāll transport my machine to and from, and pay a fair price.
Maybe ask Louis Rossmann, heād be certainly able to do such a job easily (and his soldering quality would look much nicer than the example pictures). He also seems to like the Framework and repairability.
Yes this could be an option as well, you could add a small LDO that is rated for 21V input voltage with a diode on the output as shown in step 6 that is tied to the the main battery power rail.
You can attach it on the top side near the right side image shown above of step 6:
Note: I have not tried this, so cannot confirm it will work.
Thanks. 9 months ago I penned a letter with queries but this topic has brought answers to just about all. This extra DC to DC was my suggestion.
Still Iām happy as I use the laptop some 6 hours every day and am not likely to suffer the Intel chip and ML1220 dying soon.
I do like my idea as there is less wiring and hence much easier to DIY. If I ever need to I will post, but I still have 13 months of warranty so itās all just head plans.
Thank you again for your help.
By the way, did Framework ever complain about the CPU spinning out to Intel
Oh there was another box inside that one too!
Good box for such a tiny lil battery!
Weāve reached out to our repair center partner in Germany to understand why this packaging was used. Given the batteryās classification, it might have required meatier packaging for protection during shipment, but I donāt know for sure.
Iāve done the same. When I couldnāt be bothered to recycle some bubble wrap I packaged something and posted it
but it is not defective as there was no mention either way
Itās not necessarily that easy:
āIf you are a retailer, your customers can ask for redress under the legal guarantee provided by EU law - if an item:
[ā¦]
doesnāt show the quality and performance normal in products of the same typeā
Thus, it is quite possible for a product to be considered defective even if there was no specific, exact, claim that is found unsatisfied. But, of course, the big and massive āIANALā in this one would be: how do we define whether this is, or is not, ānormalā in products of the same type? Iād personally lean towards this going against the normal for laptops, though.
But the basic idea is: if you purchase a door knob, and it breaks the moment you twist it a bit hard, the fact that the manufacturer didnāt specifically say that it could withstand that torque does not matter if the ānormalā on the market is that door knobs are fine with that. Imagine the girth of the spec sheets weād need for basically everything we ever purchase otherwiseā¦ (Obviously, might be different in other jurisdictions.)
Anyway, for this whole part of the discussion, Iām reasonably satisfied now. My own case is definitely proof that Framework does, at least most of the time, not balk at issuing replacements. (Though something seems to have gone wrong in the situation you were responding to, for sure.) And the new procedure with supplying known good and known compatible RTC batteries when this is needed is plenty enough to make myself satisfied that FW is doing what is reasonably achievable to sort things out. Itās not optimal, but I donāt think there can be an optimal in this situation.
Consumer protection rules and regs in the UK are not the same as those in the EU and never were, so I can see how US regs may not be compatible with many EU consumers expectations.
But I digress as this topic is about the viability of the ML1220 not that of the possibly inept procedures of the CPU compounded by Frameworks lack of design in having the ML1220 being charged from the main battery.
So the viability is largely down to Frameworks short-sightedness in design compacted by Intelās in the CPU cut when there is no CMOS battery.
The title of this topic was when the question was rather new, now the topic could be.
The Problems of not having the rechargeable CMOS/RTC battery being charged from the main battery.
That made me laugh.
That is not relevant though. FW sells to EU customers under EU regulations, to UK customers under UK regulations, etcetera. Setting all of that up properly was part of the reasons for why it takes time to expand availability to more countries.
The alternative would be for customers to be the importer, in which case the customer would be personally liable for import duties and VAT (like would be the case if ordering from System76 in Denver, for example).
That made me laugh.
Looking through the rules for shipping lithium batteries at IATA, the āinner and outerā box thing is explicitly mentioned as a requirement, actually. Itās classified as a dangerous good, and thus needs to fullfill a bunch of requirements to make sure no careless handler can cause a lithium fire in the cargo/post compartment of an aircraft.
So personal guess: they took the smallest box they have stocked, put the battery in there with some packaging, then took the next box size that could fit the first. (The fines for violating this stuff seem like they can be quite painful.)
Really? In the UK I have up to six years from purchase to ask for repairs etc, well outside of the general manufactures warranty offer and further support.
But to demand/expect that from a foreign company is not reasonable, it applies to the seller of the product not the manufacturer.
