Virtualization Technologies
I’ve decided to post my query here since it may be of interest to the wider community. I’m considering buying a refurbished framework laptop, but I would like to know in advance whether I will be able to run Windows as a KVM guest with Linux as the hypervisor.
It would be helpful if these specs were listed for all the laptops that Framework offers.
Short answer - yes. Longer answer, it depends if you are trying to do more than running windows and applications in a vm - things such as hardware passthrough, for example. RAM is your friend when running VMs. The more the merrier. Any of the CPUs ought to be fine.
Seems like Framework didn’t add a link to the 11th Gen laptop product page on the refurbished laptop’s store page. specs should be listed here.
