It was raining heavy and water entered in the laptop. After that I started the device and it powered on normally. After a reboot or something (i cant remember) the screen was really really dark on 100% screen brightness. After drying it for at least a week it now cant even start. I tried disconnecting the battery and booting over the PSU and that worked.
So the laptop can boot over the PSU, also runs fine with an external screen but doesnt boot with the battery attached. What should I do? Let a local PC shop clean the board?
What I already did, I replaced the screen but that didn’t change nothing. The battery has to be replaced surely but the board cleaning could be done by a local PC shop right?
Running the newest Fedora.
Which kernel are you using?
Didnt check that.
The newest version available as of november 2025.
It’s an AMD Ryzen™ AI 300 Series Laptop.
