I’ve noticed that when plugged in, the CPU will have a higher frequency, voltage, and power draw than when the laptop is using the battery, even for identical loads. This creates unnecessary heat, which I’m sensitive to, since I actually use my laptop on my lap.
I tried lowering the CPU skin temp limit and changing the boost profile in RyzenAdj, but it doesn’t seem to be doing anything. Windows power efficiency is already at Best Efficiency, so there’s nothing to do there either. I used to be able to disable boost on my AMD Surface Laptop 4 by limiting maximum processor state to 99%, but that’s not the most ideal, and it doesn’t work that well on the Framework anyway.
Does anyone know how to force the laptop to use battery power settings even when plugged in, and/or respect the skin temperature limits and disable boost when going over? This issue is not limited to Framework laptops, but since it’s the most open laptop there is, I wonder if anybody has a solution for it.
Here’s a screenshot of the temp/power chart before/after plugging in, with identical loads. I’m sure you can deduce when I plugged it in by looking at the chart alone.
While you can set the power limits to those resembling the ones you get on battery there are a bunch of things that get set based on available power (battery + 90% of charger) that you can’t override from the os.
You could edit the ec to always use the battery only limits but that might be a bit extreme. I have messed with that part of the code to experiment with eliminating the dipping into battery behaviour with some success.
There is also the part of the os that disables a lot of power saving when on external power.
I think it’s a Windows issue. I tried Windows 10 with ESU and it got slightly (but not completely) better. I then tried Fedora and I could actually set the CPU governor to behave just like it does on battery when it’s plugged in. A shame that Linux is missing things that I like and scrolling in Chromium is messed up
Windows does have energy saver and it can be manually triggered even under AC power. Otherwise, going into the power profile and limiting the amount of processor max % should achieve the same result.
Not sure about the AMD AI chips but in the Intel mainboards cores could be turned off in the BIOS. This would achieve a similar effect as fewer cores generate less heat overall.
On my AMD Ryzne 7840U running Windows, the first half of the cores are “parked” when on battery. All cores are active on AC even the power slider is set at powersave
You can’t turn on power save mode when plugged in. If you use regedit to manually limit the CPU max it will disable boost completely and limit the frequency to a miserable 2.x GHz. The battery profiles are perfectly capable of having all cores on with them boosting when needed without cranking up the CPU voltages to an insanely high level
