Web based desktop tile picker
Already posted elsewhere, but this is the design I had in mind from the start.
Heh, the downside of this is… aren’t those tiles $5 each? This might be the most expensive tile layout you could get without getting into extensive 3d printing your own tiles
The earth looking down with a concerned expression…
A maybe harder to spot reference:
Looks like markings on a space ship in a futuristic written language to me… thinking Star Trek, Firefly, etc.
Conway’s Life. Bottom one is a glider. Maybe the top one also.
Yep, both different phases of the glider pattern.
I just added customizable USB-C / USB-A aluminium variants and USB-C solid colors. I think that will be enough for most users to play around.
that should be enough for the most part. there are two more expansion cards that makes sense here, SD and mini SD.
Nice, I just ordered but I might want to change my tiles now.
I’m constantly adjusting the tiles I ordered. Right now my order contains 7 tile packs. That combination would allow me to go with three mayor styles: mix of lavender / gray, just gray, and all black. Might strip down to just 3 packs once batch 10 shipment gets close though :slight_smile:
At one point I thought about adding a feature to the panel designer I wrote to allow someone to design a bunch of panels and then it would combine the tiles into a single shopping list by only counting the most you would need of each tile to do any of the designs. I wasn’t sure how to present it as it might be confusing for some people thinking you were designing the front panels for more than 1 order instead of multiple (fickle) panel designs for one order.
Also, what if the person orders extra front panels and actually wants all of them populated so they can swap fronts depending on their daily mood?
I like the idea. Basically “starting” a design session that keeps track of all tiles used. Once one panel is completed the user could click “design additional panel” and the session still keeps track of the parts needed. User can continue to design as many panels as they want and have the total tile package list that they need to realize all the designs.
If they design multiple orders then it’s basically on the user to restart the session after each design. Not too confusing I would assume.
You’ve described myself. I might either order the minimum 3 packs or 8 packs for 3 different designs I want to set. Not daily, but I can see myself getting bored after a few weeks and wanting to change things up in a while. If I get 8 packs (most likely) right at the beginning I’m saving on future shipping costs. But not sure yet.
I like your idea, but TBH might not be worth the effort. It’s easy enough to do the math by hand with the info the tile pickers already generate. Each design tells you which tile packs you need already. Combining them is not that difficult :smiley:
Another consideration is that if someone has multiple concepts when ordering, they are likely going to have a new idea a couple of weeks after shipping or receiving anyway. Plus, I’m sure seeing it in person might be different than seeing it on a web site.
In any case, someone like that is going to have an idea later in the process anyway and so they will have to either over-order or just resign themself to ordering more later. So, the value of knowing exactly what to order for multiple ideas loses value quickly.
One thing to note, the tiles are on the parts store, but listed as “Coming Soon”. For at least the first few batches, you may have to wait if you don’t like what you initially ordered.
Thanks again for making the cool tool. I thought it would be fun to share my former design, but IRL.
I’m most likely to keep playing, but here is what it is right now :smiley:
Edited to add original design image. I’d forgeten which grey I’d bought.
Can you edit your post to add your former screen capture of the web designer so we can see side-by-side how accurate it looks?
I was curious enough that I quickly did it myself in your web app. Depending on how color accurate the photo is, I’d say some of the colors (particularly the orange) don’t match that well, but they still give a pretty good idea overall.
It looks like my colors are all washed out or desaturated a bit too much. Wolfie’s colors are closer, but the black tiles are a little “dark crushed”. I was hoping that the Framework web team would take some of these inspirations and implement something with their own artwork that was closer to what the final results looked like.
Yeah, I was going to say, the issue with the other picker is I have a hard time seeing the grain, especially on the black tiles.
One cool thing about you making the designs a shareable url is that it makes them easier for LLMs to understand/manipulate. I’ve been going back and forth with ChatGPT 5 a bit using it.
(Suddenly worried the AI bots are coming for him. Hides in a Faraday cage…)
