I tried to choose the ‘Power Adatper: None’ option but it says ‘out of stock’.
I can’t understand what it means. I mean how can ‘None’ option be out of stock.
this issue is happening when I choose Ryzen AI 5 340 + Matte display together
Off the top of my head, I’d say it means there’s a bug in Framework’s power-adapter-picker.
I’d suggest contacting support about it, they should be able to get it fixed quickly.
This could also be because the prebuilt systems (and possibly the DIY systems?) are often prepackaged together before being put into stock, so if they ran out of systems that are prepackaged without a charger, it is not a simple process to “remove the charger” from the prepackaged system.
