What s included exactly on Framework Laptop 13 Chassis?
Hi, i’ve an extra single motherboard 7640U ryzen and i want to assembly a new PC. I read the description on the website and i’ve some question.
  1. the “original display” Is the matte One? What kind of Resolution has?
  2. i Need to buy some keyboard or it’s included (for example in the Framework chassis UK the keyboard is the UK ones?).
  3. the included battery 55Wh Battery Is ok for the 7640U?
Thanks.
Welcome to the forum.
The forum here is mostly just users. You can contact Framework directly for confirmation. There is a contact link at the bottom of most FW pages.
I assume you mean this?
The description seems to tell almost exactly what’s included.
contains a 55Wh Battery, Original Speaker Kit, Original Display, Original Top Cover Kit, Black Bezel, Webcam Module (1st Gen), and an Input Cover Kit. To turn it into a complete Framework Laptop 13, you’ll need to pick up or bring your own Framework Laptop 13 Mainboard (with Storage and Memory), Wi-Fi, Expansion Cards, and Power Adapter.
The original was glossy, not matte. Specs: Framework | Display Kit
Should be included, as an “Input Cover Kit” includes a keyboard. Be sure you change your region to UK if you want UK. Then you’ll be presented with the option to choose UK £399 or DE £399. There would be no need to have seperate UK and DE versions if there was no keyboard.
Sure. It’s still a battery. Just has 10% less energy in it. :sun: What does 10% less mean for use time? Google a 7640U battery life review and if it says 61Wh, then take 10% off the use time numbers.
True, but I think Framework doesn’t manufacture the glossy displays anymore and is probably out of stock. I’m pretty sure the framework 13 case comes with the standard (low res) matte display.
