What should we build next?
My friends used to rock "laptop cooler"s that effectively pulls/pushes air from the laptop’s side vents for more airflow (And better cooling). I think someone called them “afterburners”, but I think we can have a similar system for framework. intrigued to see how the cooling work on the 16 inch.
This may turn the internal fan into a windmill that generates power. The mainboard must have the according protection, or it may be damaged by voltage from an unplanned source.
hot mainboards can get a little overcharge, as a treat :blush:
I do believe a Docking station would be amazing. A modular dock has been a long time wish of mine. While most people just expect more ports, I wish I could have a “laptop extension block”, one with an extra battery and extra storage. Since hot/swap storage is problematic, a light weight OS running a NAS would be nice. Oh well, once gone all the way there, let’s add an eInk display to double as a smart desk display/clock :wink:
I am also sure that long time customers will accumulate redundant expansion cards which could be reused for the dock.
Probably this will get very close to the desktop case for the motherboard, but I do not think it is currently that easy to turn the whole thing into a dock (like forwarding the video signal of the laptop). Also the cpu needs do not demand the power / volume of a whole motherboard
A dumb TV with a great display and remote, and without all the “smart” nonsense. I use only HDMI and Chromecast input anyway.
@Geert_Schuring Alas, I’ve decided the viable path forward is to just buy a large-format monitor. I know of at least one or two monitors that use the same panel as the LG C2.
One thing I’ve looked for and haven’t found yet is a clear plastic clip-on outer shell protector for the laptop case itself, something like this one made for MacBook Air machines.
I like to get these for a couple reasons – protection for the laptop if it gets dropped, etc., as well as a removable surface upon which to sticker away the laptop, then get another one and start over once it’s full. It would be great if Framework offered one for sale as an accessory that was made to fit on the laptops they make.
@CodeAndData yeah…I want something like that too, many on here do actually.
This would be amazing, and I could definitely get behind this idea!
you can re-utilize your old framework motherboard to do that!
Well, not directly, but you can adapt the m.2 slot to PCIe and have a PCIe storage controller card (or just split it into multiple NVMe SSDs)
It’s going to be massive jank without like customized PCB, cable and housing, but it’s doable.
And the 13 inch display can be … well, kinda up to you.
This is a great idea, it would be really nice to stick a bunch of stickers on without having to risk damage to the laptop. I’ve got a hefty amount of brand stickers lying around. I wonder if there’s a custom shop for it somewhere?
Into the portable enclosure they might make it goes XD
As others have said:
  • Phone (personally very interested on this)
  • Printer (I would not buy it, but i can see enough interest in it).
  • Game controller (would pair well with 16" gpu extension)
  • earbuds for IEMs
  • Speakers, bluetooth and normal
Also, another interesting area would be Home Automation, but I’m not sure how modular it can be made.
One part that I can imagine that can be made modular are wall switches: the microcontroller part inside with zigbee, matter, ethernet, whatever, and then different kinds of cover that can be switched, from normal typical wall switches to a small touchscreen that can recognize gestures, to just different colors and designs.
Another could be a remote with touchscreen to control TV, lights, curtains, music and anything really.
As other mentioned, air purifiers.
  • Repairable Printer/Scanner
  • NAS (designed enclosure plus rack for the storage)
  • Opensource Tablet
  • Raspberry Pi competitor with modular approach
  • Opensource accessories like Keyboard, Mice, Webcam, external and portable display etc. with open software
Why not a repairable and modular 3-in-1 3D printer/CNC/laser for the DIY sake !
Option 1: I’d say first-party accessories to the framework.
So something like logitech’s unifying receiver with support for
  • keyboard
  • mouse
  • wireless headset/headphones
Option 2: A surface-styled touchscreen -only or 360-hinged FW
option 3: self-hosted smart home network. So things like smart lights , speakers etc are managed locally with restricted internet access
Sadly 3D printers don’t work well as CNC mills and vice versa.
I’d say build a robust organisation for the long haul that’s resistant to failure. For example going public could be the death of the mission and execution of the current company. Maybe think about creating a robust non-profit or a co-op that we can help keep alive and delivering these kinds of products for decades rather than a few years.
The laptop format I did not know i wanted until i saw it:
It would be great to have a Framework version of this format, that way you can go 10", 13" or 16". Apart from making it modular, the only thing i would change is to go with AMD HS cpu instead of U, so it can be powered higher than 35w when plugged in (and connected to a eGPU), but other than that the format is great, including the oculink.
A Framework version would be ideal, including the embedded gamepad. And the gamepad parts could be compatible with a future Framework gamepad, creating a great ecosystem that could eventually even go into a Framework SteamDeck version.
Edit: Also, a modular portable screen, something similar to this: https://www.intehill.com/products/best-qled-portable-monitor-for-laptop , compatible with the screens of the 16" laptop so they can be reused as external and/or portable monitors.
Another interesting concept. A x86 tablet, with attachable controllers it becomes a game deck, with a keyboard it becomes a 2 in 1 Surface like…
Honestly, a bit thick because otherwise they have no space for the battery (screen is 8"), but great idea.
Personally I don’t intend to buy another piece of electronics for the next 4-5 years.
If you could bring something even more open than the fairphone that could be interesting to me, but I’ll only be in the market for one once the current one expires.
Honestly premium-display options for the framework 13 (OLED or the like) would be currently more interesting to me and something I’d be very willing to sink money into.
