What should we build next?
A truly modular “NUC”.
My usecase is a bit niche, since I’m mainly looking for something to use as a Proxmox box (to centralise all my Raspberry Pi stuff into one unit). What would be really amazing for me would be something that is modular in chassis, not only the system itself. So for example:
Just want a NUC to sit on the desk or mount on the back of a monitor? You get what’s essentially a Framework laptop but in a NUC-style chassis with Vesa mount. Super small and nice.
Need more of something? Add a section to the chassis, connecting to a backplane or whatnot, making it taller but giving you space for one or two SATA drives. Need more storage? Just add another section on checkout.
Sort of like the modular IO we love in the laptop, but for ultra small form factor desktop machine. (Or, in my case, ultra small for factor server to hide in a closet. :smiley: It’s so frustrating to see so many NUCs that are almost but not quite what I want. I am thinking about getting a 12th gen Framework board and then getting an enclosure printed/built to turn my old 11th gen board into that kind of NUC, but it would still get a bit awkward to figure out how to connect a good storage array to that.)
I think gigabyte had something like that at one point
Can I go crazy? Ok, let’s go!
  • Printers with ADF (Automatic Document Feed)
    • that doesn’t require electronical components to check the expiration dates and validity of ink
    • optional wlan/lan support (for those who want an usb/lan only version)
    • optional display component
  • Dumb TV that can be expanded using “expansion ports” (the same as the laptop has)
  • A Tablet which can be plugged into the “Dumb TV” (see above) to display their content on the TV (this is actually the brain of the TV)
  • A dock that is actually just a bigger version of the laptop expansion system with 6 (8?) ports.
  • Modular & smart bluetooth keyboard, attach numblock/touchpad/fingerprint sensors and program it the way you need it
(more to come)
I’m with @Marek here. The laptop market isn’t fully explored, and it lets you continue to build on your core competencies.
I’d love to see an option built on an AMD or ARM platform. The limit to Intel is one of the two reasons I’m on the fence about buying a Framework laptop.
The other reason is form factor. I’m a middle-aged geek with old-person eyesight and bad knees. Small screens and small batteries are my bane. I’d instantly buy a larger version of the Framework so I can have the things I need to operate off my dock for days at a time instead of a couple of hours here and there.
With the existing form factor, eye fatigue is going to hit me fast. The screen on my 14.1" Thinkpad is on the small side of usable…I can use it for about 6 hours/day without my eyes giving up on me. Before you say it’s quality not size, my 14" Macbook Pro is just the same. I’d also like room for a bigger battery, or an additional one. I’d much rather have a heavier, bulkier laptop than have to wonder when I’ll have to sit in a corner where I can find an outlet at some event, and possibly not get up off the floor again without help.
A 15" or 16" Framework laptop with room to build in ~16 hours of battery life would sell me fast…along with many of my colleagues.
A double-screen laptop like the upcoming Yoga Book: This Double Screen Laptop is INCREDIBLE - YouTube
Looks like the ultimate all-in-one: clamshell laptop, tablet, pen device, and large (2x13.3") screen desktop machine, in less than 1.5kg.
This is kinda random and I guess probably might not be worth it.
But a modular case like what InWin has done is really cool. Maybe an idea for a next product but the certifications and the manufacturing volume might make it very expensive for Framework though.
I have another idea though this is kinda niche again.
If you look at Intel NUC Compute Elements, they can be plugged in into the PCIe slot and act as a secondary PC for video capture/stream processing.
Maybe we can reuse mainboards to work like that too with a 3D printed PCIe adaptor and maybe a PCIe 8-pin power connector (to the battery or as a special expansion card) to power it up. When the main PC boots into Windows, it will be recognized as an additional card that can be selected for encoding etc.
Something like a Mini STX motherboard that needs an external power supply and can be equipped with a massive heat sink and a Noctua fan to make it super silent even under load.
I missed a chance to buy one of these and they don’t make them anymore :frowning:
Something I’d love to exist is a reasonably priced eInk external display that could also be used as a “tablet” connecting wirelessly to the Framework’s “brains”.
Purpose 1: Could be used as an additional monitor when docked with the Framework as a “status” display (eg put calendar, Spotify, or anything else that’s fine with SPF instead of FPS rendering speeds). Would be great to include some sort of VESA mount adaptor, so the screen can easily be clicked into and out of place as needed between purpose 1 and 2.
Purpose 2: If you need to sit and read some long documents, you can unmount the eInk display, lock the Framework, and go walk over to the couch to get comfy while reading. It doesn’t need its own brains, or at least not complex ones, as it can just call back to the Framework for any tasks beyond scrolling. eInk latency is already crap, so adding round-trip-time to eg typing a comment on said document shouldn’t be additionally too painful. And not needing its own brains should keep it lighter too!
Imagine needing to read a bunch of Confluence pages or email for work and being able to leave your laptop at your desk and get comfy, but it’s still technically on the same device (as it’s using the Framework’s brains) so you don’t have to worry about signing in again or getting a separate device accepted onto the corporate network or re-finding the documents you need; just move the windows to the right screen, sleep the rest of the laptop, and walk to the couch. And if it’s a colour eInk display, add “reviewing PRs” to that list of use cases!
Purpose 3: Not sure how applicable in the newly remote-hybrid world we’re in, but also having the ability to store hand-written notes locally and have a convert-handwriting-to-text option when back in range of the Framework, for taking to meetings. Again, being lighter than a full laptop, would be easier for those running from one meeting room to the next all day, and if there’s an option to convert-handwriting-to-text to then easily copy/paste into a Confluence/Notion page or email, I could see that being useful!
You REALLY NEED to build a good keyboard for your laptop first! A keyboard with a NIPPLE that is!
I very much want to give you the money for my next ultra portable instead of Lenovo, but this really is a deal breaker for the ultra portable!
GIVE US THE NIPPLE!!
There are a lot of people for which a laptop computer means only one thing: an Ibm/Lenovo Thinkpad! For me it’s like this for some 20 years.
This may be a niche, but one worth persuing, since most of people buying it won’t look too much at the price if the product is good. You could/should charge a hefty premium for such a keyboard. But you need to build a good product, not like the half ass solution that Dell built in their Latitude lineup.
Also consider the marketing value of the keyword that I am talking about: it will give you access to a lot of the people that decide which hardware gets bought by the company. This could get you some big, predictable revenue streams!
How about a FIDO2 Key with fingerprint support? There are not much on the market now. Maybe this could be a cool thing.
I agree a bit!
Having more options for keyboards would be very cool to appeal to more audience!
As well as more trackpad options; for instance with buttons.
I don’t miss my ThinkPad nipple, but I’d pay money for a replacement trackpad with three physical buttons.
I’m on the other side of that. I just hate trackpads in general, so I’m curious to try a trackpoint. But looking at their machines currently on offer it really looks like they’re going the full-on Macbook route. :frowning:
I think you should run with the laptop idea a bit more before moving into other products. I was just talking about Framework laptops at work with 2 other colleagues who have them and we all agreed that we love the concept and are behind it 100% but want to see more options for display panels, keyboards, and peripherals. Among the things we mentioned were:
1.) keyboards. Different layouts with the Fn and Ctrl keys swapped. A bigger 7 row with a smaller trackpad. Maybe even a trackpoint version too. If you could somehow get mechanical switch options, that would be awesome.
2.) Displays. A lower res display as an option would be nice, since scaling doesn’t always work well. Love the 3:2 aspect ratio though.
3.) More mainboard options. AMD, ARM, RISC-V, etc. This might involve encouraging other companies. Ideally Framework is not the only company making boards for these laptops. If SiFive came out with a RISC-V board for these, I’d buy one. But for the concept to really flourish, it needs more aftermarket support.
A LapDock type device based on the existing Framework chassis definitely sounds attractive to me. I’d like to see the ecosystem expand, and bringing the same product core to a broader spectrum of use cases would make sense in many ways.
And in case you’re going for a NUC type device/dock, tablet or phone next, it’s a great way to extend the ecosystem in a way that lets products play well together.
And it would play well with the module system, too. Storage is a good thing to have, if you swap between different devices.
edit: And let’s not forget that repurposing hardware is one of the main things, that make Framework attractive. Having a way to repurpose the chassis itself is definitely nice. Maybe unlocking the drive with the fingerprint reader could be a thing? Or networking if multiple ‘hosts’ get plugged in at the same time? I can even see ways to innovate on the firmware/software front because of the flexibility of the module system. And above all, it’s well in the spirit of reusability/repairability
Let me add to the ARM disussion:
ARM64 - Yes - but go mainstream enough that the investment in Python, etc. works.
Support for 128GB RAM
Intel I9 processor option
15 Inch screen option, but let me choose a keyboard without the number pad.
AMD CPU Motherboard / CPU options
A laptop shell that vents out the back of the laptop case, not the bottom.
(might solve your overheating) I’ve been told they vent out the back, if so then withdraw this one. However I don’t see adequate venting out the back. I’ll upload an example of what I’m suggesting. If it’s added to the 12th gen already, then disregard this suggestion.
A NIC module that fits the same way the other modules do. The way it sticks out, it may
as well be an old school pcmcia card. I’m still glad it got made though. No RJ45 is a deal breaker when you’re working with networking etc.
A module with 2x USB-A and or 2x USB-C ports
A new battery that would enable longer battery life. Not necessarily bigger, but more efficient.
Begin looking into solid state batteries as they seem to be one the rise.
It already does, that is intake on the bottom.
