Where do I go to download firmware updates?
I am considering buying the framework DIY for linux.
I don’t see anywhere on the website to download firmware updates. Is this done by downloading a file, or are updates downloaded inside the UEFI?
If a firmware update file is downloaded, is it OS dependent (windows only) or can firmware updates be done from any OS (linux specifically)?
They will be putting BIOS updates on LVFS:
http://community.frame.work/t/public-beta-test-bios-v3-03-driver-bundle-2021-08-31/6165
I just started using LVFS, it’s great. Unfortunately many manufacturers ignore it. It would be nice if the various components inside a Framework Laptop could be supported and the team will try to convince them:
Here’s the link to BIOS and drivers:
Per the article, BIOS updates are done within Windows, and under Linux via LVFS.
The latest beta release for 11th Gen,
