Wi-Fi degraded performance (MT7922)
Two months ago my Wi-Fi was good.
Today the average latency to my router is 125 ms (while with another laptop I’m getting 6 ms).
Also the download bandwidth is not good, it downloads at ~2 Mbits/s, while the other laptop downloads at 35 Mbits/s (tested with iperf3).
I’ve seen this framework download/upload at 60 Mbits/s on the same router with the same iperf3 setup a few months ago so it was OK.
What changed: I upgraded from Debian Trixie to Debian Forky (so new Linux kernel, and firmware-mediatek bumped from 20250410-2 to 20251111-1), and got a bunch of updates fwupdmgr.
Do anyone have similar behavior?
Please test your Wi-Fi performance (you can use https://librespeed.org/ for example) before and after upgrading if you’re on Debian Trixie.
Maybe it’s just a coincidence but when my Wi-Fi was slow I had the audio expansion card issue and now both are working. I’ll continue logging if those two issues are correlated or not.
Ohh, another finding: when disabling Bluetooth I’m getting from 3.2 Mbits/s to 78 Mbits/s (downloading).
If I re-enable bluetooth boom I’m back to ~3 Mbit/s.
If I disable bluetooth again, boom 74 Mbits/s.
Looks consistent and reproducible.
Looks related to MT7922 mediatek wifi card wifi/bluetooth issue
Yeah I’d swap that out for the Intel AX210 module. I did early this year and my wifi has been consistent since then.
Have you tried setting apt to pin the version of firmware-mediatek to 20250410-1 or removing the 2025-11-11 files and replacing with the 2025-04-10 firmware, then rebuilding your initrd with sudo update-initramfs -u?
I’m glad to hear that Debian Forky seems otherwise okay, I have yet to bring forward my Framework 13 AMD (but I started with a Intel AX210 wifi module).
^ This
My issue on a Framework 16 was that I was getting about 100 Mbps down on the Framework while other devices in the same location on the same network all consistently got 500+ Mbps.
I replaced the card with an Intel AX210 one that I got for about $20. Despite being an intel card it still works with my AMD based laptop. The physical installation was a bit fiddly getting the tiny wires connected but once it was physically installed, boom 5x download speed with no additional software installation needed on linux.
Overall I still like framework but I think they dropped the ball on the wifi testing of the card it came with, and notifying customers about it.
I think there was some funkiness from AMD requiring the problematic wifi cards that shipped in all of the FW16s. I THINK that’s true but I don’t have a good source on that.
I noticed similar behaviour with mine. My Legion Laptop sitting in parallel with my new FW16 will consistently give pings of 1ms to the router which is 3m away line of sight. The FW16 Ai9 will swing between 1ms ~ 7ms. I have set the Legion on Win11 home to the same packet size as the FW16 on Fedora KDE. So zero difference. Despite having a AX210 brand new sitting here, it hasn’t been a large enough issue to worry about (I am not a game player). There have been multiple Kernel updates, but none have made a difference…so far.
