Will Framework 16 get glass display with OLED and IPS panel?
I hope to see framework team decide to some day provide a part which is glass display without touch but with OLED panel or IPS and improved light sensor that makes brightness go up and down more smoothly. Right now i noticed it goes up and down more chunky on linux like instead of smooth it goes like 10%, 20%, 30% etc it jumps than adjust smoothly like a macbook can do. You can see it goes brighter, then darker, then brighter in a chunky steps.
What do you all here think?
Hi,
The light sensor on the FW16 is actually pretty good.
It can detect quite fine changes in brightness.
cat /sys/bus/iio/devices/iio:device0/in_illuminance_raw
The “jump in brightness” problem is caused by the way gnome handles it.
There is a whole discussion about it here:
thing is that is for 13 inch framework not 16.
So i think there needs a guide for framework 16 too. Incase of different parts/sensors being used.
Also i’m using zorin os so i would like to see easy step by step guide for that or complete .sh script doing work for me :slight_smile: to adjust sensor behaviour in linux so it adjusts smoothly.
