15” laptop
Are there any plans to make a 15” version in the future?
I would love to have a 15” framework laptop!
I hope so too mate, 13" for a laptop is ok for some tasks but a 15" one would be perfect!
Here’s my vote for a 15" (or even 16") screen version. Having upgraded from a 13" Macbook Pro to a 16" Macbook Pro last year, I can appreciate the increased screen real estate and portability is not compromised as much as you would think!
My vote is definitely for a 17 inch. I don’t use monitors, so it would be a huge plus for me.
Upvote… 15" is my preferred screen size.
Upvote - IMHO the best screen size compared to usability and portability.
I’m sure Framework isn’t going to commit to anything until they’ve successfully shipped the current device and developed the ecosystem a bit.
I’m holding out for a 15" monitor.
It’s a decent size monitor, but still easy to carry around.
Yeah having a numpad is a must for me
I also agree to 15" precisely 15.6"
A 15 would be awesome 13 works too though I’m good either way
Upvote for all the reasons listed in other posts
Yeah! 15-inche or even 17-inch would be definitely much more pleased :slight_smile:
Yes! upvote for 15 or even 17 inch screen. Is a must for me.
But please, no numpads!
A big clear screen with a centered keyboard without numpad is the perfect combination.
I’m not an Apple fan, but MacBook Pro 15" has the perfect layout.
Definitely a 15”, I want it too!
I want 15.6" too. It’s very hard to work on 13’’ if you don’t have monitor
Depending on what you’re going to use the laptop for this might be an intersting piece of information:
As the screen’s aspect ratio is 3:2 with the 13.5" screen you get same height as you would with a 15" and 16:9 wide-screen. Only to the left and right it’s going to be just under 1" shorter each.
See also here: Visual TV Size Comparison : 13.5 inch 3x2 display vs 15 inch 16x9 display
Id also appreciate a 16inch version, 17 would be fine as well.
13.5 Is just too small for my use.
Looking forward to it in Europe.
Regards,
Just another up-vote for a 15" model with centered keyboard and no number pad.
And I would like an option with a number pad.
