Lego Brick Expansion Card
Brick System Expansion Card
Turn your Framework Laptop into a cursed Lego brick! The Brick System Expansion Card provides brick studs and tubes to the side and bottom of any Framework laptop.
This is my new favorite expansion card!
Amazing! I want to put two of them in and build a ridiculous bridge between them…
Just what I need, a mobile laptop … :+1:
haha, love that idea!
This is the best yet! Now if you can just find the motor from a Technics kit and drive your laptop around the desk!
@bonkrat
Are you going to sell these the way @XenoCow is selling the SnackDrawers I bought recently?
Looks like you got some attention!
No plans to sell currently, but I really appreciate the interest!
Are we gonna get a XenoCow bonkrat collab? Lego Drawers for the framework? Gonna need a place to store all these legos
I was thinking that as soon as I saw it! Which legos and how many can fit in a standard-sized snack drawer? And of course, the snack draw should have lego pegs on the front.
Someone bothering you at work?
Open snack draw facing the perpetrator, click on two angry lego eyes, close drawer. Say nothing.
From the looks of it, it might be possible to fit the four studs on the slide of the medium drawer and replace the extra space with the female side. So, you’d end up with a normal volume drawer but with the lego connectors on the front and bottom.
@bonkrat, how tall are the studs?
The studs are 1.8mm in height and 4.8mm in diameter.
My FrameWork may just give me the push I need to get into 3D printers. I love gadgets and tech but I could never really think of anything useful I would want to make at small scales such as I’ve seen in youtube videos and such. These ‘drawers’ fit that requirement plus I could probably come up with some bracket variations to fit inside the FW16 rear blank (or discrete graphics module slot on the rear).
Keep up the good work coming up with creative ways to enhance/customize our laptops!
This is how I got into the hobby, the Fidget Spinner Expansion Card was the first project that I printed. I used an online printing service and it cost around $50. Once I received the print, it was nice but there were some design issues. I didn’t really want to spend another $50, and I had a bunch of other dumb projects I wanted to prototype. I ended buying a Prusa MINI+.
Printing was an easier hobby to get into than I anticipated. I’d recommend it if you’re into design and have ideas you’d like to try.
Hey. Quick question, because I’m interested in building a Lego throne for my laptop… Could this be made as a case for the original type C? With the bottom be able to receive bricks? I would hate to lose the charging, but love to have it higher from the desk with stable Lego based legs
It definitely can, I’ve seen some similar feedback since this was posted. Another quick project I posted could help here: Lanyard Loop Expansion Card Mod (and base mod files)
I could merge the Brick System Expansion Card and the base mod file from above. I’m thinking of keeping two studs on the outside, and having the card stick out a bit instead of being completely flush on the bottom for the tubes. This print would allow you to unscrew your current USB-C card and replace the shell with the brick system one.
Drilling and gluing is, while exactly what I usually would love to do, is not what I had in mind. I rather it look like it was meant to be like that. And yeah, female holes on the bottom of the card, preferably at positions so if I change the left and the right side both (or al six) they would stay in Lego alignment (long parts could connect to all of them at the same time)
That is what I was thinking, yeah. Je be so great having that printable, maybe in resin, transparent, and switch out the cases of all the cards!
Quotes for on demand prints around ten quid, which is nice.
I get some warnings from online print shops about “Walls are too thin, minimum recommended thickness value is 1.0” - from https://makeitquick.co.uk for instance.
As the Lego clutch walls are less than this, is there a particular material/process I should be picking to minimise any issues ?
