13" AMD - Keyboard has stopped working, as well as the power light
Hi @Shamyl_Zakariya,
I’ve checked on your ticket and following the history, you reported the issue on November 18th, and we started troubleshooting with you but you had requested to close the ticket on November 22nd as your issue had been resolved. You wrote back in on December 7th on a new ticket and we began troubleshooting with you again but the issue again self-resolved and you had mentioned you would report back if the problem happened and our team asked if we could get any videos if the issue reoccurred. We’ve responded each time you’ve written in, but based on your reports, and the lack of requested video, we still aren’t sure that the Input Cover is the cause of your reported issues. I assure you that we’ve taken you seriously since the first time you wrote in, but the problem appears to be intermittent, and there are gaps of time between responses. If you could please provide the information requested once you are able to reproduce the issue, that will help our team determine if hardware replacement is necessary. If you respond back here letting me know that’s been done, I’ll take a look and will authorize an RMA if it appears the hardware replacement will resolve your reported issue.
Thank you.
I did reply with video over the weekend. But you have to understand, I don’t know when this problem will occur. It’s essentially random. It wasn’t until this weekend that it occurred in a context where I could film it.
Further, I’m not a hardware engineer, I am not qualified to diagnose. All I’ve been able to do is observe that when I removed the input cover and re-seated the main ribbon cable connecting it to the mainboard, my machine would work again. I didn’t realize early on that “work again” could mean 12 hours, or 2 weeks. Now that I’ve been through this 8 or 10 times, I know that that “fix” just resets a timer.
I also don’t know how many insertions that plug is rated for. How many more times can I do this before my mainboard is ruined?
Anyway, I didn’t realize that the fix was temporary earlier, which is why the first ticket was closed. Once I understood the nature of the issue better I opened a new ticket. Can you blame me?
Apologies for the rant earlier, I’ve just been very frustrated.
For clarity, on Saturday I did provide a google drive link to Support to a series of videos showing the problem. I would have done so earlier, but I wasn’t asked for video until a week or so ago, and it didn’t occur in a context where I could film it until this weekend.
Also, Support asked me over the weekend to update firmware on my SSD and reset the mainboard - I’ve done both. Right now my machine is working, but as I’ve reported, it could fail in the next 15 minutes, or it could fail in a week. I have not found any way to force the issue to occur, all I can do is use my laptop and keep my fingers crossed, and report when a failure occurs.
I completely understand you are frustrated, and I can also understand why you are frustrated because who wouldn’t be when experiencing issues with a purchased product?
Our team has been trying to understand if this is hardware or software-related, and our troubleshooting steps help us determine if hardware replacement is warranted. Our product allows us to to troubleshoot with customers given the ease of getting to the internals and swapping parts. This said, the vast majority of the time, reported issue resolution does NOT require hardware replacement which avoids unnecessary shipment of new hardware and returns of perfectly working hardware that then has to be tested at a repair center just to confirm that fact. There’s cost and time associated on all sides, and if we are able to determine that replacement is necessary, we of course honor our warranties. We just haven’t reached that conclusion yet given the information provided, and the fact that it’s working after some minor changes points to something else going on, and our team is just trying to figure out what that is.
If it happens again, please provide the details on what happened and let the agent know about this thread. I’ll work to authorize the replacement at that time. Thanks.
Thank you - like I mentioned earlier I’m not always in a position to record when the failure occurs, but I’ll do my best to record it again the next time it happens, and will share that video with the support team.
I’m experiencing the same of very similar symptoms.
I just plugged my 13" AMD to Dell 27" screen over USB-C and got dual displays (ie: desktop over the two screens) as is normally the case, but this lasted only a second and then the laptop’s screen went black, the keyboard stopped responding and the power button LED turned off. I’m currently writing the with the external keyboard plugged into the external screen.
I’ve had the laptop for about 3 weeks and have used in this exact configuration (laptop + external USB-C screen with keyboard connected to screen) since day 1 and it worked fine until today.
I faced the same issue earlier, as i tried to bring the laptop out of suspend having plugged in the USB-C screen while it was asleep. The external screen came on but at the wrong resolution and the laptop screen stayed off. After a reboot, the keyboard was still not functional.
Luckily, after unplugging everything, closing the laptop as if to suspend it and opening it back up got me a functional power button, so i was able to force power off and reboot.
I’m running Fedora 39 Silverblue. I’m going to try rebooting in an earlier generation to see if it makes any difference.
I suggest you try resetting the mainboard, and updating your SSD firmware. I can’t say which of those resolved the issue for me, but one of them did. My machine’s been solid since Jan 7th when I did that.
Thanks @Shamyl_Zakariya, helpful ideas.
I’ve not experienced the problem recently, but have smaller bits of weirdness.
fwupdmgr doesn’t find updates for my WD BLACK SN850X sadly, so figuring out how to update the SSD is next on the list.
Maybe someday fwupd will update our SSDs, but not yet. In the mean time I had luck back in January following this thread here:
And this script here:
Note: The script back in january supported Fedora linux, but now seems not to? It also might work just fine. IIRC, I did some manual execution of the script step by step for sanity checking. But in the end, it worked, and my problems went away.
First gen batch 7 (Order date Jan 04 2022), my keyboard failed Jun 14 2023, it wasn’t a full loss of function, but I was losing keys I could use for input. Never contacted support as it was out of warranty at that point. However it started where re-booting would resolve the issue this eventually stopped so I just switched to a blank keyboard.
Good luck, I hope your keyboard doesn’t fully go out like mine did.
I am experiencing this intermittent and frustrating problem as well; I’m on a laptop-13, 11th gen Intel running ZorinOS v.17.3 pro. Basically if I press the power button and it lights, then all is good and the keyboard is responsive, however, quite often I press the button, it doesn’t light up and the keyboard is dead. The laptop boots, and the decryption password prompt is displayed, but then I’m stuck. The solution (as others have observed) is to dock it and then the power button lights every time and I can enter passwords &c. using either external keyboard or the laptop keyboard, which I find strange. Basically the dock is the “starting handle” when the starter-motor fails :slight_smile: . The problem started for me after I upgraded the BIOS from 3.17 to 3.22; suspecting that was the cause, I subsequently upgraded to 3.24 but no dice, it’s still happening in a random way, which means I can’t rely on it away from home.
I will try some of the fixes suggested above (e.g. mainboard reset) but thought I would report this to assist in the troubleshooting.
Arthur
p.s. dumb question, how do you reset the mainboard? Just unplug the battery?
I have a FW13 with Ryzen 370, Running Ubuntu 24.04. About once a week, sometimes more, the EC (Embedded Controller) appears to lock up. (Theory) The Keyboard, power button, and touchpad are all dead, but the machine is otherwise working OK. I can plug in an external KB and it’s fine. The only fix so far is issuing a reboot. If I issue a power down, then I have to open the machine and disconnect the battery to reset it. A reboot is the only fix, and this is super annoying! This is my second FW machine, and I had a lot of trouble with my first one too, the OG 11th gen. At this point I doubt I’ll buy another.
Yes I tried reseating the KB cable. It doesn’t appear to be physical, like jostling the machine doesn’t do it. It’s not a suspend wake issue. Seems to happen if I walk away for awhile then come back, screen is still lit, but all input is dead. It feels like the whole machine is locked up, but it’s just the input. All programs continue to run normally.
More details: Embedded Controller (EC) Lock up on FW13 Ryzen 370 - Keyboard/Power/Touchpad inop
Hi there, got the same issue on my framework starting yesterday. I tried resetting the motherboard and stuff and nothing worked. What seems to have fixed it for me is changing the slot my USB A expansion card is in.
I have 3 USB C cards and 1 USB A, originally the A one was in the bottom right slot. I swapped it to the lower left slot and the keyboard started working again.
I doubt the expansion card is faulty since any device plugged into it works. So I guess it’s more likely the motherboard’s fault.
