13" forgets expansion module
USB port - that I use for phone pad charging and wireless mouse - goes dead occasionally. Resolved by ejecting module and reconnecting but I shouldn’t have to do that… what’s the fix?
Thanks
?.. I searched ‘expansion module’ and nothing came up…
No solution?!.. Jeez…
Adam_M,
Maybe this Community search thread list may help provide some issues with USB expansion modules not responding or appearing dead:
http://community.frame.work/search?context=topic&context_id=55629&q=USB%20Expansion%20port%20stops%20responding&skip_context=true
Thanx,
Wio
Texas Citizen
Use USBC instead of USB-A. I recently discovered that when using USB-A as power output, the power will be cut if the current draw is above 1.6A despite ports rated 3A. Many USB-A peripherals like older(before usb power delivery) power banks or 18650 li-ion charger or flashlights that draw 1.6 to 2.1A that are fine on other computers can’t be used on framework laptop 13.
Charlie_6,
That’s a shame. I prefer USB-C but purchased a set of USB-C to USB-A adapters for some of my rare legacy USB special use cases. I purchased only one USB-A module to test some of my LIVE USB thumb drives with until I read about the phantom power use of the USB-A modules a while back. I don’t know if that ever got resolved or not.
Thanx,
Wio
Texas Citizen
I guess to maybe boost this a bit and add my datapoint for other folks who might run into this issue, I just ran into this and had to search for quite a while before finding this thread.
I have a power bank that, when attempting to charge from the Framework 13 using a USB-A port, causes the USB-A expansion module to shut off until it is disconnected and re-connected.
I don’t currently have any other devices that have caused this so far, which seems to back up one of the above posts mentioning certain power banks and chargers causing this due to current draw.
