I’ve got a new 250GB expansion card in my new 12 inch framework and it’s warm even when not mounted. It’s definitely not dangerously warm and it works but, it’s a bit unconfortable when used on the lap and I don’t think it should be generating heat when it’s not being used. If it’s constantly wasting my battery then I probably wont want to leave it in there when I’m not using it, at which point I’m not really sure why I should have it as an expansion card rather than a dongle (apart from the reduced risk of breakage).
I have an older SanDisk USB drive with an A & C connector that gets stupid hot when plugged into USBC for whatever reason. Even if it is just “idle”. Someone can probably chime in as to the reason it gets so warm aside from the fact that if it is “plugged in” the OS sees it as an active drive mounted and polls it regularly.
I’ve got a 1tb (1st gen, i think?) card and a i5 FW12, and yeah mine runs hot too. I wonder the same about its usefulness as an expansion card if it’s drawing power and getting uncomfortable while not in use.
Also, my FW12 is set up with dual boot (Fedora 44 KDE & Windows 11, although this problem was still present back when the Linux install was Fedora 43 Workstation). Strangely, when booted into Windows, the drive stays cool while plugged in.
