3D Printed Magnetic Stand for Framework 13
Hi everyone, I made a 3D printed magnetic laptop stand for the Framework 13, primarily to make it quieter without having the laptop suffocate when I’m using it in bed or on the couch. I have not come across anything that fits my use case, so I’m sharing it.
The stand attaches to two rails that you stick on the laptop with mounting tape, and the rails do not protrude further than the rubber feet on the chasis, so the laptop doesn’t rock when it’s sitting on a hard surface without the stand attached.
I’ve posted it on Printables, and I’m sharing it here in case someone else would find it useful. I’ve been dailying it for about a month and I’m really happy with it.
It looks good! Maybe put some vent holes in the stand? With it installed, it looks like the bottom vent is inside a pretty small pipe?
