61Wh battery becomes 55Wh battery after 140(?) cycles, voltage drop 0.2V
I suspect that this battery has planned obsolescence. During the first half of the year of usage, the battery was at 100~101% health. Near one year usage the battery health suddenly went to 91%(may occasionally float to 95%).
System: AMD 7840U, with 61Wh battery (limited charging voltage 17.8V)
No BIOS update was done, the BIOS stays at 3.05
Arch Linux(6.13.6-arch1-1)
61Wh and 55Wh photos from official marketplace
However, notice the “Desired Voltage” half a year ago.
Desired voltage 17800 mV
$ sudo ectool battery
Battery 0 info:
  OEM name:               NVT
  Model number:           FRANGWAT01
  Chemistry   :           LION
  Serial number:          0035
  Design capacity:        3915 mAh
  Last full charge:       3755 mAh
  Design output voltage   15480 mV
  Cycle count             48
  Present voltage         16542 mV
  Present current         3630 mA
  Remaining capacity      620 mAh
  Desired current         3915 mA
  Flags                   0x0b AC_PRESENT BATT_PRESENT CHARGING
And here’s now
Desired voltage 17600 mV
Battery 0 info:
  OEM name:               NVT
  Chemistry   :           LION
  Serial number:          0035
  Last full charge:       3558 mAh
  Cycle count             145
  Present voltage         17416 mV
  Present current         2450 mA
  Remaining capacity      2562 mAh
  Desired current         2740 mA
(ignore the 3915mA to 2740mA, the current reduces when charging past 4.15V/cell since the very beginning, i.e MCC-CV charging)
Since now the battery health is 91% and 55/61=0.9, I can safely assume that the battery has 0 wear. The 9% wear is due to the voltage being ARTIFICIALLY reduced from 17.8V to 17.6V
Any explanation of that? I appreciate that the battery is available and can be replaced easily, but blocking the original voltage and creates the illusion of battery degradation is, well, unethical and unsustainable.
No more after a year, despite 0% wear
Exactly. But not because of the BIOS, but the battery management. It would by very difficult if not impossible, for an average joe to hack the BMS and get the full capacity back.
Hacking the BMS of a laptop is so niche that very few people know that it exists. Combined with less Framework users compared to other popular brands, which means remedying this problem is a nigh-impossible task. The battery is also not standardized, currently there’s no third-party manufacturer of the battery, unlike other brands like Lenovo, ASUS or System76.
Found out that the 61Wh battery just means you pay more for a premium to unlock more capacity, said premium will expire after roughly a year(may be different, your mile may vary).
battery life is unpredicitable and highly variable. If you feel like your battery has worn beyond what is expected contact support.
Update to the latest bios, I belive that should be 3.07, their exist some improvments to the battery managment, aimed at improving battery life/health.
/Zoe
Hah, no. Definitely don’t do that. 3.07 is in beta and it has a bug that is causing the battery limiter to stop working. You can see the wall of bug reports about the limiter in the bios beta thread.
A stopped working limiter is akin to a turned off limiter. So the max voltage should be the same on both 3.05 and 3.07 with battery extender off and charge limit 100%
Yeah it’ll be the same, but you won’t be able to turn that limiter back “on” and you won’t be able to downgrade back to 3.05. I assume as someone who is so concerned about your battery health that you’re not normally running this without the charge limiter enabled?
I enable the charge limiter to 75%, I only set to 100% when doing a cycle to calibrate the battery gauge, or read the (more accurate) battery health.
55/61 is 90.16%
Your 91% to 95% is higher… you’d expect a gradual reduction in capacity over time that would pass through 90% on the way down.
You can not safely make the assumption that a battery that’s been used for a year has 0 wear. That would be impossible. Batteries degrade even sitting on a shelf.
Furthermore, I think you’re misreading your ectool output. “Desired voltage”, if you look at the ectool code, is described as the desired charging voltage, which would be higher than the voltage produced by the battery while discharging.
15480 mV, Design output voltage, is probably the number you’re thinking of, in your ectool output. If the battery is asking for 17.6 volts instead of 17.8 volts to charge, that’s just a gentler charge.
Why the battery is asking only 17600mV when it asked 17800mV last year?(and the Limited Charging Voltage is 17.8V). I also found the 55Wh battery asking 17400mV instead of 17600mV after being used for a while
It’d probably be better for an engineer to answer since my entire expertise is hazy notions I got from watching videos about cell phones or skimming explanatory web pages about battery chargers.
From what I think I understand about battery charging, 17.6 V is still a high enough voltage to get the battery full, since its operating voltage at a full charge is only 15.48 V. Because current = voltage / resistance, the lower voltage will just result in a slower current, charging the battery to full more slowly.
Doing it slower would generate less heat, and generally be easier on the battery. Maybe the reduced voltage target came from a BIOS update, as part of the fix for those issues with the 61 Wh batteries, or maybe it’s normal over the lifetime of the battery based on some model of their internal chemical degradation over time.
Something like that would be my guess.
I replied here to prevent off-topic
I praise the design of the laptop for easy battery replacement and inexpensive batteries. However if the 0.2V charging voltage is confirmed to be very common(not just my case), I’ll criticize the (relatively minor, almost unnoticeable) planned obsolescence from the battery manufacturer at the same time.
Here are other cases
Then his battery
Here’s my case in April 2024
This was the same battery (I only have one 61Wh), note the cycle count 29 and desired voltage 17800
That’s what you would expect though. As your battery degrades, you want to charge it slower over time.
Here, this is a paper I found about EVs, just searching around randomly: Lithium-ion battery aging mechanisms and life model under different charging stresses - ScienceDirect
From the abstract,
It is indicated that charging current and cut-off voltage should be reduced to retard battery degradation when the battery degrades to a certain extent. The time when the loss of electrode material accelerates is taken as the crisis to reduce charging current and the time when the loss of lithium inventory accelerates is taken as the crisis to reduce charging cut-off voltage.
Lower charging voltage will cause the charging current to be lower, which will charge the battery slower, while physically / chemically breaking it down less.
So the battery engineers have models so that when they’ve got some indication that the battery’s x% degraded, they lower the charging voltage, to maximize its life as much as they can. That’s what you’re seeing. If the BMS kept trying to charge your battery at the same voltage level as when it was new, the battery would just degrade faster and die sooner. Lower charging voltage == more cycles out of your battery.
Tesla used this as an excuse to cause up to 20% of artificial degradation, multiple, times.
I worked as an electrical engineer a while ago and part of my work was with battery. I measured the voltage-capacity curves similar to this one for a variety of make and models under different voltage and temperature. My company has a 5kW electronic load, more than enough to test most batteries for portable devices.
My working experiences with batteries is the reason I discovered the sudden capacity drop caused by the artificial 0.2V voltage downgrade.
In April 2024 I posted my measurement of discharge curve
measurement
The 61Wh battery, when charged to 17.6V, is only 91% full. Note the 100%, 17784mV. Due to internal resistance, the voltage drops slightly after charging, in this case, a 16mV drop.
We already have that, it’s “Battery charge limit” in the BIOS settings. Typically, the battery is charged to 16V(4V/cell, 60% setting), to 16.8V(4.2V/cell, 80% setting), when plugged in. Only charge to 17.8V(4.45V/cell, 100% setting) when you absolutely need it.
I set it to 75% in BIOS most of the time for the whole year, only charged to 100%/17.8V in less than 5 times. as a result, the battery degradation is very small, 33mAh, 0.84%, less than 1 percent a year.
My battery’s actual health is 99% or more precisely, 99.16%, but why I only got 91% health on the reading? This is because the battery only charges to 17.6V instead of 17.8V, The battery is only 92% full, 1-(1-0.99)-(1-0.92)=0.91
I, as a battery engineer, maximize my battery life as much as I since from the very beginning, limiting the charge of my battery to 75%(4.15V/cell) and I only charged it to 100% in less than 5 times in a year.
As a battery engineer, I also know that if you lower the charging voltage for 0.2V in a 4-cell battery, the battery will only be charged to 92% full. If the user(or the computer) doesn’t know it, they will believe that the battery has 8% degradation, in my case, 1% actual degradation, 8% artificial degradation caused by BMS misbehaving, 9% displayed degradation. That’s what you’re seeing.
Sorry if I bothered you. Maybe I misunderstood the “Desired Voltage” term. My copy of ectool doesn’t display it. I still think you’ve probably got causality backwards though.
Actually, watching ectool as my laptop charges and discharges, I misunderstood Design output voltage too, thinking it was the ceiling, not the average or so.
I looked into the EC code in
and I found
static const struct battery_info adl_info = {
	.voltage_max = 17600,        /* mV */
	.voltage_normal = 15400,
	.voltage_min = 12000,
	.precharge_current = 72,   /* mA */
	.start_charging_min_c = 0,
	.start_charging_max_c = 47,
	.charging_min_c = 0,
	.charging_max_c = 52,
	.discharging_min_c = 0,
	.discharging_max_c = 62,
static const struct battery_info rpl_info = {
	.voltage_max = 17800,        /* mV */
	.voltage_normal = 15480,
	.precharge_current = 80,   /* mA */
static struct board_batt_params info[] = {
	[BATTERY_ADL] = {
		.design_voltage = 15400,
		.batt_name = "ADL-55W",
		.batt_info = &adl_info,
	[BATTERY_RPL] = {
		.design_voltage = 15480,
		.batt_name = "RPL-61W",
		.batt_info = &rpl_info,
Note that for the 55Wh battery the max voltage is 17600 and the normal voltage is 15400, for the 61Wh battery the max voltage is 17800 and the normal voltage is 15480.
For my battery if I used $ sudo ectool battery I got
Battery 0 info:
  OEM name:               NVT
  Chemistry   :           LION
  Serial number:          0035
  Cycle count             145
Why my 61Wh’s Design output voltage is correctly shown as 15480 mV but the Desired Voltage is only 17600 mV? I’m pretty sure that the Desired Voltage was 17800 mV last year
Does it also only charge to 17600 when you charge to 100 or does it go to 17800? This may just be a readout error or something.
Assuming the desired output voltage is correct, then your desired voltage is wrong(?). A 55Wh battery cannot output 15480 mV. Only a 61Wh battery can.
I’m making some assumptions there, and might be wrong, but that is the logic as I interpret it.
It only charge to 17600, during and after charging. Not a read out error, upower confirm that the actual voltage is 17.57V at full charge.
The output voltage is always correct, 15480mV. The desired (charging) voltage was the correct 17800mV last year and should be 17800mV according to battery specification and BIOS EC code. However it became the wrong value 17600mV this year, and the battery health decreased from 98% to 92% suddenly as 17.6V is not fully charged but the system now believes 17.6V is the full voltage.
I believe this is more reflective of a bug in the EC code, than the actual reported voltage value. The values of voltage in this regard are hard coded into the structs defining them. I am still looking over the code, but I do not see where the actual read / reported voltage from the EC is being used. (I see that an battery identifier is being reported from the EC, but this is not voltage, and is just a name, essentially.) OR your 61wH battery is now reporting a 55wH max voltage. Which, I guess, is also possible. Need to do some more digging.
I looked at the code and I think the BIOS EC recognizes the battery model and set the voltage based on the model. And I can only find 17600 for 55Wh and 17800mV for the 61Wh in the code. Both are correct. I think it should be hard coded
However if you look over this reply and this one, you’ll find that the 55Wh exhibit the same problem, the “Desired voltage” is reported as 17400mV instead of the correct 17600mV, which is DEFINITELY a bug as NO battery for FL13 should be fully charged at 17.4V, NEITHER 55Wh nor 61Wh is limited to 17.4V charging voltage.
