When I install a Samsung 96 GB LPCAMM2 module into an Intel Core Ultra X7 358H Framework 13 Pro it fails memory training every time with error 0xDF29. Specifically after powering on it shows the “MEMORY TRAINING IN PROGRESS” screen, then a fraction of a second later shows this error below: “Memory not properly installed. Guide at fr.mw/FRANNBSK01. Error0xDF29”
Some more info:
Model number: M561K6LC3CL1-CCVXD
Part number: 96GB 2D8Rx8 PC5-9600-FE1-1111-NT
Rated speed: 9600 MT/s
Tested in both the 3.02 and 3.04 BIOS.
It has the E1 pinout and I’m using the stock E1 interposer
I believe it’s not the laptop or interposer that is faulty as a 32 GB Crucial (CT32G85C2LP5X) works fine.
FWIW, after giving the BIOS and error code to an LLM it suspects the 0xDF29 error corresponds with this MRC checkpoint for the Intel FSP: 0xDD29 / MRC_SENSE_AMP_OFFSET.
Has anyone got a 96 GB LPCAMM2 module running in a Framework Laptop 13 Pro? I cannot find anyone else who has reported trying this module, or any 96GB module for that matter.
There are so few of those in the wild right now it could be hard to pin point.
Is that a 9,600 mhz module? It could be related to speed timings from the module too. Maybe look up from Samsung who’s devices it was tested or certified with to get an idea.
Something that large and at that speed is really specific and may have some custom tweaks to get it working with the right boards. Which would explain why it is failing on the Framework board but maybe not for the intended laptop manufacturer it was designed around.
Like the other poster asked, where was it acquired from and for how many thousands of $$$. There are not even hardly any LPCAMM2 modules for sale at all let alone anything that large.
@Kieran_Levin would the Framework team like to use my module to determine if this is a firmware issue? I am in San Francisco and work a few blocks away from Framework’s HQ. I am planning on returning the module before the return deadline on November 25th, but I am happy to lend it to you until then. I would of course prefer not to return it so if there’s any chance this is a firmware issue I’d very much like to help determine that before my return window ends.
Where on earth did you manage to buy that? I haven’t been able to find >64 anywhere.
Ebay.
It is a 9,600 MT/s module. I have not seen any reports of anyone trying a 9,600 MT/s module of any size.
Same failure on a second unit: same Samsung M561K6LC3CL1-CCVXD, Core Ultra X7 358H, stock interposer, Error0xDF29 on every boot. The module works in the ThinkPad P16s Gen 5 it came from.
Support promised to escalate my case (2IK4WQBK) on 29 October, but I haven’t heard anything since, so I’m happy you’re bumping this! There are more of us.
Have you considered setting any of the NVRAM variables that modify the FSP’s memory settings? For example, SaSetup’s Maximum Memory Frequency or DDR PHY Safe Mode Support bits?
I have not tried them as I’ve been testing the memory in my friend’s Framework while I wait for mine to arrive. It’s possible that modifying the wrong NVRAM values could brick or physically damage your board or RAM. There’s no documentation around setting these hidden NVRAM variables, nor whether they can be reset to factory defaults with a board reset.
Did some additional reading and the nuts and bolts are that if it was designed for 9,600 it may not (and probably was not) tested or validated for significantly slower speeds as this is costly to do.
The chips could have that ability, however the module does not have the “timing” (which I use loosely here) because it is not like clocking down other memory. It has to be notched down at just the right subtiming and be able to be reported as capable of clocking down that low.
Apparently Lenovo has the most experience with these modules and because they were primary made with their devices in mind they only had one or maybe two timings in the SPD values on the module because anything more costs extra and virtually nobody else was having modules made in the volume that Lenovo was.
Odds are good that if it does not work out of the box, very little could be done to “make” it work at slower speeds for the Framework boards.
Also there is a key note in the deep dive article that was published. The main boards were capped at the posted speeds because going higher would have raised the manufacturing and design costs for the bleeding edge speeds. So the smart choice was made to design them around the 7xxx and 6xxx speeds because that was the most cost effective while still being significantly faster than DDR5 speeds on their other boards.
Sorry for the long winded explanation. Hopefully this helps explain some of the background of why a faster module doesn’t work in a slower speed rated board.
Considered it, but I’m not convinced yet. SaSetup looks locked on every boot, so how would you write it? setup_var gets WRITE_PROTECTED on other Framework boards.
From what I can tell, the SenseAmp step doesn’t read any setup value, so I don’t see how max frequency or safe mode would change it. Do you have something that points the other way?
And if a bad value stops the 32GB from training too, what’s the way back? I found no reset that runs before memory training, so I think it means an SPI programmer.
Did Framework answer your offer to lend them the module? That still looks like our best chance.
