Does Framework Laptop 13 Pro support 96 GB LPCAMM2?
I’m talking about these ones: Samsung readies LPCAMM2 LPDDR5X modules with up to 96GB and 9600 MT/s | TechSpot
I found different information on this.
The specs page of the 13 Pro says “up to 64 GB,” and the physical RAM slot also states (according to some videos I saw) “up to 64 GB,” while the RAM page states:
The LPCAMM2 LPDDR5X 8533 memory modules are compatible with Framework Laptop 13 Pro motherboards featuring Intel® Core™ Ultra Series 3 processors and support a single module with up to 96 GB
So, assuming they become available at some point, will I be able to use a 96 GB LPCAMM2 module in a Framework Laptop 13 Pro?
Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3) supports one slot of LPCAMM2 memory up to 96GB at the native 7467 MT/s speed. It is compatible with LPCAMM2 modules with memory speed rated above 7467 MT/s, but the speed will be capped at 7467 MT/s because of the platform limitation. Grabbed from our KB Article: DRAM/memory supported by Framework Laptop 13 Pro (Intel® Core™ Ultra Series 3)
I’ll flag the specs page to the team. Thanks!
If Framework adds official support through future BIOS and firmware updates, the Laptop 13 Pro may be be able to recognize higher-capacity LPCAMM2 modules. Until then, it’s safest to rely on the memory capacities listed in the official compatibility documentation. BulkDevices also provides helpful resources for users researching compatible hardware and upgrade options.
In the review from ifixit, the reviewer calls out that it does support up to 96GBs even though it says 64GBs on the heat spreader. I would assume ifixit would not say that if it hasn’t been tested, but can’t be 100% sure until someone actually does.
