Hi - I’ve just started running FreeBSD 14.2 on my Framework 13 Ryzen, set up by my usual setup scripts.
Things are going great! The Intel WiFi board I purchased is working with the iwlwifi drivers (albeit slowly; but that was expected). Even the USB-C based Ethernet port works. The graphics also run fine with amdgpu.
The only remaining issue that’s vexing me is the inability to suspend or resume. If I look at what’s available:
$ sysctl hw.acpi.supported_sleep_state
hw.acpi.supported_sleep_state: S4 S5
So obviously trying to sleep in S3 fails with:
$ sudo acpiconf -s 3
acpiconf: request sleep type (3) failed: Operation not supported
If I try -s 4, the screen blanks, but the power light stays on, and ditto the keyboard backlight. Pressing the power button does nothing at this point; I have to hard reset the machine.
A similar behaviour happens on halt -p. The system halts, but does not power off, leaving the power button and keyboard illuminated.
I tried looking through the docs but couldn’t find any indication of whether (a) I need a particular kernel module for this hardware, or (b) what the state of suspend / resume is on the Framework.
Anyone have any guidance / docs suggestions / etc.? ![]()
[This is cross-posted to the FreeBSD forum.]
