So I was not enjoying the display in low light conditions in KDE. The last keyboard step before “off” was 5%, which was still pretty bright for when my girl was trying to sleep. The KDE systray power and brightness slider allowed me to get to 1%, which was better but still not perfect. So I went researching and found this:
Turns out, writing to /sys/class/backlight/intel_backlight/brightness by doing
$ echo 1 | sudo tee /sys/class/backlight/intel_backlight/brightness
does in fact put the screen as low as it can go before off. I am adding this to my custom bin directory to either set it to 1, or to whatever command line argument is given, as:
You can also turn off the display completely by writing 0 to that file. The script can be made to allow this by changing-gt (> 0) to -ge (>= 0), and then passing in 0.
On my daily driver install (EndeavourOS, plasma, X11), I can actually hit 0 brightness via hotkeys, so I didn’t need that in script. But the last step of hotkey controlled “on” was still like 5%, which is actually too bright for a fully darkened room. I was mostly wanting the script to automatically hit 1 brightness if no value was specified. But your edit to the script makes sense also.
