The Scenario
My working desk is in the same room that I sleep in, and I charge my FW Laptop at night, so I have it ready for university the next morning. I need a dark room to be able to sleep, but the FW charging LED is super bright. To be able to sleep I currently put some clothes on top of the laptop, which is annoying to do every evening and probably not the most secure thing to put on top of a charging device ![]()
Workarounds I have considered
- Some people suggest removing the light pipes or desoldering the LEDs, which for me is not an option as I don’t want to do permanent damage to my FW.
- I have seen other users being able to control the LEDs via
ectool. I tried but didn’t get it to work (it was unable to connect to the EC). I have the AMD model, maybe that’s the problem..?
My Suggestion
- There is already an option to control the power LED brightness in the BIOS. It would be cool to have a similar setting for the charging LEDs; Something like
bright,dimandoff. - Of course when disabling the charge LEDs, you lose the ability to check whether the laptop is charging at all and whether it is fully charged. For me this is a good price to pay because I can be sure the battery will be full after a full night of charging and even if I want to know the charge I can just check my OS.
- BONUS: If you want the LED to be off, but also want to check whether charging works when plugging in the cable, there could be another option called
indicateorflashor something, which when plugging in power will quickly light up the charging LED to show it is charging and then after a few seconds switch it off.
I’m pretty sure I’m not the only one having this issue and would be very happy to hear your solutions to this problem; But I’d be even more happy to hear from the Framework Team, whether the fix mentioned in the My Suggestion section is something possible and worth implementing! Thank you!
