I run Ubuntu (on the latest release, though it also applies to 22.04) and the ambient light sensor works fine. The problem is that it is so sensitive that I have turned off auto-brightness. If I’m using the laptop with a lamp behind me in a dim room (this is often the case), small position changes in the machine like picking it up or shifting angles will cause the brightness to flap around wildly. It seems like automatic brightness responds in real time to the output from the sensor, which makes for a jerky and distracting auto-brightness experience.
Is there any way to tune auto-brightness to behave differently? Can I configure it to respond to, say, the past two seconds’ average ambient light reading instead of reacting in real time?
Hi! Came across this thread experiencing same issue. I have been working on gnome extension that provides improved brightness control based on ambient light sensor. In addition, it also has an option to enable keyboard backlight in dark conditions on supported devices. Will appreciate any feedback. It’s now published at Adaptive Brightness - GNOME Shell Extensions
