AMD 7040 series with eGPU as primary display
Is it possible to use an eGPU as the primary display on an AMD 7040 system? By this, I mean to be able to see the BIOS and initial boot output prior to the OS level display drivers taking over?
I see another similar question, but no firm answer:
I also see indication of a beta BIOS for Intel systems that seem to potentially support this:
Hi,
The last message in this thread appears to confirm that the answer is no, re bios screens on eGPU display.
That’s another of my posts, I’m hoping someone (other than me) might have some insights that I’m not aware of.
On my Framework 13, 7840U and an eGPU (Sonnet 750ex with 6800 XT), I do not get any output with the eGPU on boot. In fact, running Windows 11, I consistently get sent to Bitlocker recovery if it is plugged in while booting, with output only on internal display. I doubt that disconnecting the internal display would help, but if you would like, I can test it.
No need to test it, it won’t help. The eGPU displays do not work until after the OS has started and loaded drivers for them.
