I was wondering what direction the community thought Framework would go for the Ryzen CPUs for the Framework 16. It seems unlikely they will offer 4 SKUs (Ryzen 5/7 U series, and Ryzen 5/7 HS series) as they’ve mentioned in the past that having too many configurations made it difficult for them logistically. So do you think Framework will go for better battery life with the U series, or go with the better gaming/performance with HS?
I personally just want any configuration that allows for 8 hours of battery use so I don’t have to bring my charger to work. If I can get it with HS, i’ll take it, but don’t mind going to a U if it helps me reach that benchmark.
