AMD Framework 13 7640U - Display is using >9W of battery at 30%
Resolved by: “Downgrading” from 23.10 to 22.04 Ubuntu with OEM Kernel. Sway seems to be slightly more efficient than Hypr.
Hi Folks! Per title, framework is awesome, and I’ve spent a lot of time optimizing my battery use. Somehow, my display power consumption stays high no matter what display % i have it set as.
Is this normal? And what are some places I should look to help myself out?
Self-Checklist:
  • [x] Did you follow everything here for your platform? Optimizing Ubuntu Battery Life
  • [x] Latest Kernel and BIOS? Ubuntu 23.10 @ Kernel: 6.5.0-21-generic.
  • [x] powertop --calibrate? Check.
The battery reports a discharge rate of 10.4 W
The energy consumed was 203 J
The estimated remaining time is 3 hours, 26 minutes
Summary: 2502.9 wakeups/second,  0.0 GPU ops/seconds, 0.0 VFS ops/sec and 64.4% CPU use
Power est.              Usage       Events/s    Category       Description
  8.79 W     32.5%                      Device         Display backlight
  964 mW      8.5 pkts/s                Device         Network interface: wlp1s0 (mt7921e)
  146 mW    324.8 ms/s      41.0        kWork          commit_work
  • “Hypr/Sway?”: Sure but that shouldn’t affect the power consumption of the display backlight, and they all record roughly the same power consumption.
Would installing amd64-ucode (the amd microcode) already be done with the kernel or maybe you could try installing it separately
Appreciate your comment! I had the same thought a while back i think, it is at the latest version currently.
amd64-microcode is already the newest version (3.20230808.1.1ubuntu1).
amd64-microcode set to manually installed.
dmesg
[    0.593311] microcode: CPU0: patch_level=0x0a704103
[    0.593324] microcode: Microcode Update Driver: v2.2.
Given my whole laptop idles at <4W at 20% having the display alone use 9W at 30% sounds a bit unreasonable, you sure powertop isn’t just confused?
That is really weirdly high. The datasheet from the display’s manufacturer indicates that at 100% brightness the backlight consumes a max of 2.8 W and the rest of the display’s components consume a max of 0.6 W for a total of 3.4 W (which is also listed as the max total power for the display).
Haha I think that was quite likely. Powertop does like to be fickle sometime. But after various testing (powerstats, etc), it seems to confirm the usage. Also at near-idle with 31% brightness.
  Time    User  Nice   Sys  Idle    IO  Run Ctxt/s  IRQ/s Fork Exec Exit  Watts
10:07:11   0.4   0.0   0.7  98.9   0.0    1   2019   1639   18   18   20   9.19
10:07:21   0.4   0.0   0.7  98.9   0.0    1   2022   1646   21   20   21   8.75
10:07:31   0.4   0.0   0.7  98.8   0.0    2   2077   1691   21   20   21   8.45
10:07:41   0.4   0.0   0.7  98.8   0.0    1   2051   1715   20   20   20   8.33
10:07:51   0.4   0.0   0.7  98.9   0.0    1   2150   1776   20   20   20   8.24
10:08:01   0.4   0.0   0.7  98.8   0.0    1   2017   1705   21   20   21   8.15
10:08:11   0.4   0.0   0.6  98.9   0.0    2   2021   1656   20   20   23   8.22
10:08:21   0.5   0.0   0.7  98.9   0.0    1   2015   1658   21   20   21   8.25
10:08:31   0.5   0.0   0.7  98.8   0.0    1   2081   1746   21   20   21   8.23
10:08:41   0.4   0.0   0.6  99.0   0.0    1   2139   1764   19   18   75   8.46
10:08:51   0.4   0.0   0.7  98.9   0.0    1   2168   1777   20   20   21   8.50
10:09:01   0.4   0.0   0.7  99.0   0.0    1   2066   1682   21   20   21   8.33
10:09:11   0.4   0.0   0.6  99.0   0.0    1   2045   1705   20   20   20   8.31
10:09:21   0.4   0.0   0.7  98.9   0.0    1   2051   1716   21   20   21   8.25
10:09:31   0.5   0.0   0.9  98.7   0.0    1   2050   1754   21   20   21   8.19
10:09:41   0.4   0.0   0.8  98.8   0.0    1   2037   1720   20   20   20   8.16
10:09:51   0.4   0.0   0.7  98.9   0.0    1   2054   1693   20   20   20   8.13
10:10:01   0.4   0.0   0.7  98.8   0.0    1   2043   1689   21   20   21   8.23
10:10:11   0.6   0.0   0.8  98.6   0.0    1   2777   5390   25   21   25   8.47
Even when it works well it is at best doing educated guesses, other times it is just doing wild guesses XD.
I do wonder where those 9W are going, it’s very unlikely to be the screen, how new a kernel are you running (latest can mean a lot of things) and are you running amd-pstate active or something else?
w. respect to amd-pstate, I don’t think I have changed anything in my /etc/grub yet.
So not very new then XD
Yeah I am going with your cpu isn’t powersaving right, no idea why powertop attributes that to the display but powertop being powertop I guess.
I would give this OEM D kernel a try, I found this linked in a framework guide for installing Ubuntu
(Ubuntu 22.04 LTS Installation on the Framework Laptop 13 - Framework Guides)
Haha I just realized it is not October 2023 now. Man time does fly.
Quick update, new kernel 6.7.6. Still roughly the same story. Maybe it is ubuntu @ 23.10 that is the problem.
  6.70 W     31.4%                      Device         Display backlight
  827 mW     81.1 ms/s     496.7        Process        [PID 3102] Hyprland
  568 mW      9.2 ms/s     363.7        Timer          tick_nohz_highres_handler
  199 mW      3.4 ms/s     127.1        Process        [PID 1102] [gfx_0.0.0]
  134 mW      2.4 ms/s      85.8        Process        [PID 17] [rcu_preempt]
  125 mW     10.4 ms/s      75.8        Interrupt      [117] amdgpu
  118 mW     34.7 ms/s      59.9        kWork          commit_work
Ubuntu is a supported os so you should be fine if you use the right one, not my field of expertise though I tend to roll a bit more bleeding edge
FWIW, AMD FW 13 running Bluefin… PowerTop said the battery was discharging 21W, with display taking 40%. I ran through a bunch of tunables and now it says it’s discharging 9.2W and the display is taking 57.6%.
That’s a big improvement!
If that’s idle numbers that’s still quite a lot.
It was idle-ish, but screen brightness up and a bunch of Chrome tabs open.
Right after rebooting, with the screen brightness down, it was running at 4.6W. Brightness up goes to 6.5W.
What’s a good score?
Who would have thought that reinstalling 22.04 with OEM kernel just… works.
TLDR: Installed 22.04 alongside 23.10, worked out of the box. 3.6W Idle at 30% without tuning kernel cmd-line wise.
I just bought mine recently (will arrive on Tuesday) and it said specifically don’t use the regular kernel in an email yesterday - those who purchased it earlier, would not have gotten that I’m guessing as it keeps getting updated and improved, there should be an easier way to stay on top of these things tbh.
But its always a good idea to keep going back to the guides and checking if your has been updated.
