AMD Framework 13 - Display connection limited
Loving my AMD Framework 13, but I’m having a weird issue.
On Windows 11 I get “Display Connection Might Be Limited” when i plug my AMD Framework 13 into my dock.
From what I can see it doesn’t seem like anything is malfunctioning.
I’ve tried both port 1 and 3 as those are the ones that support display output.
The dock I’m using: Anker 778 Thunderbolt Docking Station
My monitor the dock is plugged into via DisplayPort: Dell S3220DGF
I’m wondering if it’s centered around the dock being Thunderbolt 4, while USB4 doesn’t have the same exact functionality. If so, then it’s not a problem.
Any advice would be appreciated!
I can’t be the only one this happened to
I get this on both a Framework and a Lenovo PC, when I plug in my Belkin dongle hub, after the PC has booted.
It may indicate a driver issue, but I have not pursued it.
On the occasion I have used the HDMI port in the hub, the video has been fine. Wasn’t checking audio.
Thanks for the reply! There doesn’t seem to be anything “not working” from what I can see. I guess I’ll ignore it.
I figured out the issue.
My port/slot configuration was as follows:
  1. USB-C
  2. HDMI
  3. USB-C
  4. USB-A
This error message was caused by an HDMI port being in slot 2 (which doesn’t support display output)
I didn’t put it together originally because I was using port 1/USBC to connect to the docking station so didn’t even consider port 2.
