After a lot of experimenting, I’ve come up with a bezel for the framework 13 that’s easy to print and assemble:
It only takes ~$1 in filament per bezel and some 10mm nickel plating you can find on Amazon. It’s based on the original model by Ingegneus (can’t link that many because I’m a new user) but features many modifications to simplify it. Do note, one of these modifications is dropping the camera and mic switches for complexities sake.
You can find the bezel on makerworld and printables
