Are RTC batteries strictly necessary to operate AMD laptops standalone?
OS: Windows 11
Framework Version: AMD
I bought a mainboard and cooler master case to operate standalone and realized too late that an RTC battery isn’t included in recent boards.
At first I had trouble accessing the BIOS to the system in standalone (multiple threads detailing this problem for AMD boards - alternating blue/red lights, difficulty getting the board to output to hdmi) and finally just transplanted the board into my laptop chassis.
After editing the bios, installing Windows, and transplanting back to the standalone case, the blue/red light problem is gone – the board now outputs solid red/blue/green lights on the side that is plugged in, but will not POST. Power button brings the fans online for a second or two before stopping.
While troubleshooting the new lights, THAT is when I learned the board didn’t ship with an RTC battery (d’oh), so I assume my BIOS has reset itself after disconnecting the main battery from my 13. But if that were the case, shouldn’t I be back to square one with alternating red/blue? I can’t work out why the light output has changed.
Obviously the next troubleshooting step is buy an RTC battery but I’ll be overseas and outside of a Framework delivery region for months, so in the meantime I’d like to try to diagnose what is happening while I figure out how to get an RTC battery brought to me.
  1. What does solid red/white/green lights mean when plugged in standalone, and the laptop will not post?
  2. Is an RTC battery strictly necessary to post in standalone? I understand what has been written here but I wanted to understand if that means it’s necessary to keep the system running as normal, or if it’s more narrowly necessary to get the system to post at all.
Thanks.
Welcome to the forum
I don’t know myself. But just for clarity on what you’re asking, you’re suggesting setting up your system initially with a main battery connected, then removing it once it’s fully booted? And also reconnecting the battery for any reboots.
If you don’t get an answer after a while, you can try contacting FW support. It’s possible that no one who sees your post has tried this.
Thanks for your reply.
I am not suggesting that. The goal is to have a normal functioning standalone computer with no need for a main battery at all. So I think I’ll ultimately need an RTC battery.
But since I can’t get one for the time being, I’m trying to understand how useable this device will be for me without one in the short term. I fear the bios standalone setting will be erased every time the board is powered down. And since I’m having difficulty getting the system to post at all without a main battery… i fear it’s mostly a brick until I figure out how to ship an RTC battery to myself.
One of the questions that I have during this period of waiting is what does a Solid red, blue, green LED mean on the side of the board that is plugged in?
I think at minimum, BIOS settings will be lost if AC power is removed.
I’d suggest experimenting a little. Connect the main battery and AC, set standalone mode, then remove the main battery. I suspect it will be fine once started. Then try a reboot with AC still connected, and no main battery connected. If it boots fine, then try after leaving it off for a few hours, again with just AC connected. Far from ideal, but if it’s otherwise unusable, you might as well try while waiting for an RTC battery.
Since you’re currently traveling outside of Framework’s shipping areas, you could contact https://frame-parts.myshopify.com/ about sourcing an original FW RTC battery.
Worldwide Shipping
Shipping around the globe, making parts accessible to all members of the Framework community
UK Based Stock
All stock listed on the site is based in the UK, allowing for speedy shipping gloablly
Parts Request
If you need a part that is not on the website, just get in touch and we can order it in for you
Non Profit Parts
For AMD laptops:
When used standalone, i.e. without a laptop battery, you do need the RTC battery.
Otherwise, whenever you unplug the PSU, the BIOS settings are lost.
The laptop battery can also power the RTC, so that is why the RTC battery is not needed if you have a laptop battery.
@James3 Thanks for your reply. Interestingly, I’ve been experimenting a lot and while I haven’t been able to boot at all, I did manage to bring up the BIOS once – and despite neither an RTC battery nor main battery connected (and many hours unplugged e.g. definitely no power in the board for a long time), the BIOS has preserved the standalone setting.
I don’t know how that’s possible – I’m not a BIOS expert, but maybe there’s some non-volatile memory somewhere that plays a role, but someone has assessed it is unreliable so they strongly recommend RTC batteries for reliability – or maybe I blindly switched it to standalone myself using a keystroke at power-on. I have been trying all sorts of things while experimenting and may have done so.
Interestingly, this post claims the system CAN run fine without an RTC or main battery. I haven’t been able to re-create their success yet but it’s encouraging that I might be able to get some use out of this system while waiting for a battery.
On that note, @MJ1 thank you for the link. I’ll check this out.
Edit: It looks like the re-seller doesn’t have the RTC battery (very limited stock it seems) and furthermore despite saying they offer worldwide shipping, the dropdown list at checkout only supports countries in Europe. I do appreciate you sharing the link though! It might come in handy in the future. And perhaps there are other shippers out there doing something similar that might be of more help. I will keep looking.
I’d suggest contacting them. They do say on the front page that they can order something if what you need isn’t listed. For shipping, it’s possible for some regions they might have to do things manually, get a shipping estimate & create an special order.
Replying to my own thread to keep things updated for if/when others arrive here with similar questions and problems
While awaiting delivery of an RTC battery (finally on the way via the kindness of a friend) I’ve continued to experiment and have been able to somewhat reliably get the system to both power on and function without an RTC battery. I can confirm that it DOES work with a small bit of fiddling.
I haven’t identified the exact ritual to get it to POST reliably every time, but keeping a keyboard and HDMI cable plugged in + a combination of hitting the power button every so often + 10 second hard reboot + spamming F2 will usually get the system powered on within a couple minutes. Sometimes it takes me to the BIOS first, but then selecting boot from the BIOS works 100%.
This is not an acceptable longterm solution – but for now I’m giving things the benefit of the doubt because I’m still running it in an unsupported way (no RTC).
My current problem is that I cannot get the system to play nicely with my dock. USB passthrough for peripherals works fine but display and eGPU (the thunderbolt stuff) do not work at all. Connecting my eGPU gives a Windows error that “Thunderbolt device functionality may be limited”
The only troubleshooting advice I’ve found for that error online suggests the cable might be bad, but my AMD framework 13 laptop (7840U) works fine with this dock and this cable.
If an RTC battery doesn’t get things reliably powering on and connecting to thunderbolt, that is no bueno. I bought this board so it could function as a docked desktop. I’ll have to reach out to support at that point.
Thanks again to all who’ve helped out with ideas.
The investigation continues…
Did the RTC battery help? Did you get one? Is your Dock working now?
I’m curious too if this worked. I’m facing a similar issue where, with my standalone AMD mainboard, my thunderbolt dock will only be recognized by my dock if it’s powered first on another port before plugging in the dock. If I plug in the dock without another external power input, the dock will not be recognized and e.g. HDMI will not work.
I’m also considering the RTC route - but I’m not confident that that will work.
Very curious how it went for you!
I have a similar issue with my AMD board. Standalone mode enabled prior to pulling from the laptop. I got it to work without RTC battery. It seemed kinda random, took some fiddling with SW1 and SW3. Next morning, it doesn’t wake up from sleep. Just a constant white light (R, G, and B) and no display output (DisplayPort). Got a support thread going, so we’ll see how that goes. The RTC batteries are in stock so I might just go for it.
Edit: I tried pressing SW1 a few times rapidly and did get it to boot and display. Weird. Everything’s in tact, but as expected the system time is wrong.
Edit 2: datetime fixed itself when I logged in. Must be hitting the network. Now I need to figure out how to wake the computer up from sleep.
Edit 3: my temporary workaround is to disable sleep and only have the display turn off. Will be monitoring my electric bill lol.
