Considering purchasing a DIY and I have these parts from another laptop
SSD
[Western Digital WD Black SN750 SE NVMe M.2 2280 1TB PCI-Express 4.0 Internal Solid State Drive (SSD) WDS100T1B0E]
RAM
[G.SKILL Ripjaws Series 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600)]
I have a pair of G.Skill modules with the same specs and they work at 3200 MT/s only via XMP or if manually configured to do so. So, unless you manage to change the default (hidden) settings in UEFI Setup, they’d work but not at full speed. G.Skill has a note to that effect on their product page:
This product requires enabling XMP in BIOS to operate at the rated speed. Otherwise, the memory kit will operate at the default speed set by the system.
Yours could be different though if it’s another part #. Mine is F4-3200C18D-32GRS (a set of 2 F4-3200C18-16GRS).
As @Fraoch mentioned, the RAM you have should work at the full speed.
It is running 1.2V natively, so XMP is not necessary to achieve those speeds.
Most RAMs require 1.35V to achieve the rated speeds, so XMP is necessary (basically “overclocks” the RAM voltage).
Since Framework laptop does not support XMP, it can supply only 1.2V to the RAM, so any RAM which is rated @ advertised speeds @ 1.2V will be compatible at full speed.
Otherwise, it’ll be at whatever the stock speed is for the RAM @1.2V (~2400/2666 MHz).
Just providing a little bit more detail in addition to the previous comments.
