Audio hiss and popping when 3.5mm used - win 11
Hi,
I am using the latest mobo bios and the windows 11 beta driver pack.
When I plug in a 3.5mm headset I get the following intermittent issue
3.5 mill plugged in > popping sound from headset > constant hiss sound > sometime later > popping sound > hiss goes away - rinse and repeate
looked at issues at win 11 / dirver level and am on latest updates there
all audio devices and setting seem to be in order and no output is detected from the audio mixer or on the advanced sound setting.
when other audio is played the hissing sound is still there in the background, have rules out the headset being an issue as they work fine with other win 10 laptops and android phones
edit -
persists through restart and when shutting down as windows closes the audio pops and hissing stops
on start up as windows loads there is a pop and hissing starts
See the existing thread on this:
Hi @Daniel_Mothersole. I would recommend submitting a ticket to our support team here: Framework | Support so they can ensure your laptop is performing as intended!
Thank you and stay safe!
