Battery drains completely while suspended, BIOS completely reset as well
I have started to suffer from battery drains and shutdowns while suspended.
I would either notice my framework running hot while suspended or having powered off completely.
This time it was particularly annoying. My BIOS reset completely as well, which I think is a red flag, something I have only seen with a faulty CMOS battery.
My framework is only three months old.
I have checked the systemd logs, and everything is in order, suspend entry is set and no logs while suspended.
Which Linux distro are you using? NixOS
Which release version?(if rolling release without a release version, skip this question)
(If rolling release, last date updated?) Yesterday
Which kernel are you using? 6.12.45
Which BIOS version are you using? INSYDE Corp. 03.09
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) AMD Ryzen 7040 Series
Please contact support and we’ll have the Linux team help you out.
