Battery/electrical issue
Hi everyone,
This is my first post here, so feel free to ask clarifying questions.
I recently started running into an issue with my FW13 intel 12 gen (3 years old and used by a graduate student), where it will start to feel “fuzzy” when it is plugged into a charger. I started noticed it a few days ago. I thought it was the current charger I was using, but it has showed up with subsequent chargers that I have used.
The areas that feel the most amount of electric fuzz are the bottom right and the top left areas of the laptop. I have tried removing the battery and examining it for visible damage with no luck. I am going to spend time later today removing the battery and then plugging it in to trouble shoot that way as well. I downloaded BatteryInfoView and it says that my battery health is around 88%.
Followup: I tested my laptop to see if the electrical feeling occurred without the battery inside and the feeling is still present.
Does anyone have any ideas as to what may be happening? I have also opened a support ticket and will update if there is movement there.
This is probably leakage current from the charger. The allowed limits for that are unfortunately well above the perceptible threshold for most people (especially in places using 240V mains). Also kind of a downside of “premium” laptops with metal shells
There are chargers that have less of it or even none in the case of properly grounded chargers with a ground connection.
Assuming you have a charger with proper safety ratings that aren’t faked this is likely harmless but can be quite annoying.
Hi,
Try using a charger that has 3 mains power pins.
If this does not help, you might have faulty house wiring.
See if the problem disappears if you plug in at a different building.
That will identify the house being the problem.
I was thinking it was also leakage from the charger as well. I have since tested it with different chargers that don’t have a grounding wire, so I’ll see if that is a help. The thing that confuses me the most is that issue is a recent development after using the laptop for 3 years with a charger that didn’t have a grounding wire.
If it’s a different ungrounded charger that isn’t that weird, the ammount of leakage current varies wildly between models. If it’s the same charger that is a bit weirder but it could still be potentially caused by you being somehow better connected to ground and there are a hell of a lot of factors influencing that.
It has as much to do with the circuit your device is connected to as the charger you’re using. Are you using it in a different place than normal?
See also:
Thank you for this information. I am curious about how my laptop felt fine for the first 3 years of use, but has recently started this up. Is there a reason this would start up? Are there wires that could be shifted around that could cause this issue?
No, this is 100% caused by current leakage. As I said, it is as much to do with the circuit you’re plugged into as the device or the charger. If you’re using your charger in a new location, sometimes even within the same building, or if you recently had electrical work done (including at the street by your power utility), any of those could be enough to cause this. It’s impossible to know for sure what caused it to start now, but its harmless and quite common on metal-bodied laptops.
Okay, thanks for clarifying. I’ll get a power cable with a grounding cable and update this thread.
I got a grounding wire charger and it did help with the sensation but it was still present. I think this issue a bit more sever than just the power cable. I have contacted support and they are going to take a look at it. I’ll send another update then. My hope is this issue can be identified and help anyone else who has started experiencing this type of issue with their framework laptop.
